Convertion
Old Jul 23, 2018 | 03:53 PM
schwa709's Avatar
schwa709
Convertion
How do I make a clutch linkage to work with a 396 chevy and original '55 pedal
Old Jul 23, 2018 | 04:13 PM
Mixer man's Avatar
Mixer man
Maybe go with hydraulic clutch setup? Or just work out the geometry.
Old Jul 23, 2018 | 04:18 PM
CharlieLed's Avatar
CharlieLed
That is not a very common engine swap for these trucks so I don't think that you are going to get the kind of answer that you are looking for. This will be a one-off fabrication effort so if you have the skills then get on with it...if not, then it is time to find a local shop who can fabricate it for you. Good luck...
Old Jul 23, 2018 | 07:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That's one reason you see so many automatics with nonstock engines in 53-on trucks
Old Jul 23, 2018 | 08:02 PM
Mixer man's Avatar
Mixer man
I just noticed that this was your first post. Welcome to FTE schwa709!
I thought you were one of the regulars due to the complexity of your question
Old Jul 24, 2018 | 10:18 AM
petemcl's Avatar
petemcl
The best answer is to put a Ford Y Block engine back in the truck. But if you insist then Speedway, Jegs and others all carry hanging pedals and hydraulic linkages.
Old Jul 28, 2018 | 11:33 AM
schwa709's Avatar
schwa709
Thanks to all!!
workbox72
May 29, 2019 10:14 PM
Justin16
Dec 1, 2012 06:25 PM
octaneforce
Apr 5, 2011 01:36 PM
desperado_18_2000
Nov 18, 2003 09:45 PM
