From a rolling start, I can light up all 4 of my 19.5's in 2nd gear on my F450 (no torque mgmt in 2nd on a DRW). It would absolutely roast the tires in a SRW.
I can light up the passenger rear tire even with my 11K toy hauler connected. That may be may be more of a statement about the lack of "stickiness" of the OEM tires than it is about the torque management.
Is the torque management still active when a trailer is connected?
I was towing home sunday afternoon in very heavy rain. About 20 minutes from home I have to negotiate a pass through the Blue Ridge that has a stoplight at the bottom of a moderate climb. It was raining pretty hard and I was trying to climb the grade after leaving the stoplight. I was listening to music when it seemed the truck was struggling to climb the grade and instantly noticed the TC light started flashing on the dash. I turned off the music and focused on making the climb. It was actually difficult to get the truck to accelerate up the grade without spinning the rear tires, even being very careful with throttle application. Switching over the 4wd solved the problem instantly. Although I could easily spin all 4 tires if I tried more than adequate throttle.
As the incline increases, the tongue weight decreases (less "normal" force as described in the world of physics). Yet the "load" (pull force requirement) increases with the incline. It's a double whammy; you loose traction but gain sensible load. Add in some Friction Modifier (rain) and it does make for issues such as you describe.
Had the same problem leaving stop lights on level ground, through 3rd gear.
I do understand the load transfer issue. I am a vehicle dynamics engineer.
