Ram 1,000 lbs Torque - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 01-14-2019, 08:16 AM
TrikeDawg's Avatar
TrikeDawg
TrikeDawg is offline
TrikeDawg is gaining momentum as a positive member of FTE.
Ram just announced the new 6.7 Cummins has 1,000 lbs of torque. I wonder how much torque the 2020 Superduty will have?
https://www.roadandtrack.com/new-car...specs-hp-info/
Old 01-14-2019, 09:21 AM
fordmantpw's Avatar
fordmantpw
fordmantpw is offline
fordmantpw is a splendid one to beholdfordmantpw is a splendid one to beholdfordmantpw is a splendid one to beholdfordmantpw is a splendid one to beholdfordmantpw is a splendid one to beholdfordmantpw is a splendid one to beholdfordmantpw is a splendid one to behold
1005 for the 2020 Super Duty.
As always, the Ram HO version is only available on DRW models.
Old 01-14-2019, 09:49 AM
SDcrewzer's Avatar
SDcrewzer
SDcrewzer is offline
SDcrewzer is gaining momentum as a positive member of FTE.SDcrewzer is gaining momentum as a positive member of FTE.
And does/will Dodge limit engine torque in the lower gears in a manner similar to Ford’s 6.7 + 6R140?
Regards,
Jim / crewzer
Old 01-14-2019, 09:55 AM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Paw's 150 Lariat is offline
Paw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to behold
Originally Posted by SDcrewzer View Post
And does/will Dodge limit engine torque in the lower gears in a manner similar to Fordís 6.7 + 6R140?
Regards,
Jim / crewzer
I would say yes to keep the drivetrain intact!!
Old 01-14-2019, 10:33 AM
nick112288
nick112288 is offline
nick112288 is starting off with a positive reputation.
I do think it is kind of dumb to offer multiple power levels, but you can get the HO with a 3500 SRW AISIN. You do get penalized heavily because of the added weight of the AISIN vs 68rfe, but it can be done.
Old 01-14-2019, 10:37 AM
lawdogg149
lawdogg149 is offline
lawdogg149 is starting off with a positive reputation.
The 1000 ft lb torque number has been a target for a long time. Wonder how long until we see 1500 ft lb. Glad to see the competition. Now ford get off your asses.
Old 01-14-2019, 10:49 AM
Sonny Crockett
Sonny Crockett is offline
Sonny Crockett is starting off with a positive reputation.
A cool milestone but more power than anyone will ever need for a pickup.
Old 01-14-2019, 10:57 AM
Redrockerstl55's Avatar
Redrockerstl55
Redrockerstl55 is offline
Redrockerstl55 has a good reputation on FTE.Redrockerstl55 has a good reputation on FTE.
They surely will limit torque in the lower gears...no truck in this class needs 1,000 lbs of torque in the first couple gears.
Wonder if Ford has any torque limitations with the frame they use vs the Dodge frame (which is what helps give the Ram a towing/payload advantage)?
Love the truck wars...the customer wins as the big corporations battle it out for supremacy!
Old 01-14-2019, 10:59 AM
acadianbob's Avatar
acadianbob
acadianbob is offline
acadianbob is gaining momentum as a positive member of FTE.acadianbob is gaining momentum as a positive member of FTE.
Wink
Yes, but how do you keep the rest of a Dodge intact . . .
Old 01-14-2019, 11:01 AM
17 Oaks's Avatar
17 Oaks
17 Oaks is offline
17 Oaks is a splendid one to behold17 Oaks is a splendid one to behold17 Oaks is a splendid one to behold17 Oaks is a splendid one to behold17 Oaks is a splendid one to behold17 Oaks is a splendid one to behold17 Oaks is a splendid one to behold17 Oaks is a splendid one to behold
1000 lb T is only attractive because of what it implies. But the difference between Ford 935 and 1000 is not only negligible, but 1000 plays and looks better, better eye candy, that's it. That said the Ram PowerWagon is rated at 35,000 towing. It's a game and it for bragging rights. About the most I have ever towed has been 16-18 thousand lbs and that was some years back with my 2011 Dually, forgot how much torque that engine had but on the trip form Phoenix to San Antonio I was driving 65-70 with no issues. Does my '19 F350 do it better? It's mostly subjective but yes it appears to be easier and stronger and maybe I get a bit better MPG due to the extra torque as compared to my '11 or even my '15, but it's measured in .1 tenths.
That said I am a fighter and a winner, so Ford get in the race and let's win!
Old 01-14-2019, 11:02 AM
tony m 6.7's Avatar
tony m 6.7
tony m 6.7 is offline
tony m 6.7 is starting off with a positive reputation.
I got a good chuckle out of this!! Reminds me of a 2003 Dodge we had in the fleet.
Redrockerstl55
Ha Ha...duck tape and prayers. LOL. Joking of course.
Old 01-14-2019, 11:08 AM
tony m 6.7's Avatar
tony m 6.7
1500 ft lbs. would put it in Class 8 territory-13-16 liter diesels, 1500 is commonplace for those, and many are up at the 1800-2000ft lbs range with HP between 450-600. Lots of twist there for sure. It's quite amazing that modern day pickups are putting out more torque and hp than 60's era semi's did.
Old 01-14-2019, 11:14 AM
Redrockerstl55
Modern P/U trucks have 1/2 the engine size but now about 2/3 of the torque and about 80% (close average depending on truck) of the HP.
Modern day diesels are built to last millions of miles and have a frame and transmission that are a magnitude stronger than today's P/U trucks.
I an agreeing with your statement..I just hope that as we hit these 1,000 ft lb milestones reliability and longevity are still somehow maintained.
Old 01-14-2019, 11:17 AM
ShadowGrey's Avatar
ShadowGrey
ShadowGrey is offline
ShadowGrey is gaining momentum as a positive member of FTE.
If I can't get the hauling job done at 450 hp and 935 ft/lbs torque in my F-350, I probably need to call United Van Lines/Atlas to come get it or make two trips...
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
