Clean Wheel Knuckle?
Old Jul 22, 2018 | 06:27 PM
dethpulse's Avatar
dethpulse
After scrubbing with 3M pad!
Hey guys,
I am replacing my 2003 7.3's front wheel hubs and brakes. When I removed the old hub, I realized how filthy the mating surface to the knuckle was totally crapped up. I didn't want to wire wheel the surface for fear of scratching the hell out of it. Any suggestions on how to clean it off, or is it good enough to grease up the inside and just install the new hub? Also, the spacer that is inside the knuckle goes with the groves facing inward, correct?
Old Jul 22, 2018 | 07:35 PM
dethpulse's Avatar
dethpulse
Update - I just put the new one on, after greasing the inside etc. I found a video and it looks like the spacer has the 4 groves facing inward from this video:
. If anyone can confirm I did it correctly I would appreciate it . I'll see from the other side which way that spacer faces too....
Old Jul 23, 2018 | 09:31 AM
CanyonRider's Avatar
CanyonRider
I use a wire wheel to clean the knuckle surface with no worries.
The fiber thrust washer should be installed with the grooves facing inboard.
As bad as that bearing was, I'd carefully inspect the stub shaft for wear at the bearing surface.
Good work!
CR
Old Jul 23, 2018 | 02:00 PM
dethpulse's Avatar
dethpulse
Ok, I have an extra o ring, so I’ll pull the hub back off and drill wire wheel it to clean it up. The inside surfaces actually look ok, it’s just the outside area due to rust that looks horrible.
Old Jul 23, 2018 | 06:32 PM
dethpulse's Avatar
dethpulse
Canyon, I also applied a thin layer of timken bearing grease to the fiber thrust washer and the inner metal seal it sits on, is this correct or should I brake clean off those areas.?
SCFoyil
Jan 22, 2018 05:34 PM
jsleona
Mar 2, 2007 12:49 PM
tbarn
Nov 15, 2006 09:36 PM
ksvtwin
1983 - 2012 Ranger & B-Series
Dec 20, 2004 03:02 PM
LV Dan
Oct 7, 2004 02:06 PM
