Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
oil pan blues
Old Jul 22, 2018 | 02:10 AM
Yusuf125's Avatar
Yusuf125
oil pan blues
Has anyone successfully mig welded an oil pan? Mine is a 77 F-250 (Motor size 460? maybe? I bought a filter for a 460 and it fit so...), with a pretty sizeable crack about an inch away from the drain plug/hole. Normally I would just go to a scrapyard, but this is serious bow-tie country, and, apparently, was back in the seventies too, so the Ford parts are pretty rare.
I was also thinking about J-B Weld, and wondering if anyone has a story or two about that.
Old Jul 22, 2018 | 07:45 AM
tjc transport's Avatar
tjc transport
i ain't rite
i have, both with mig and stick welder.
it is better to remove the pan and clean it real good before attempting to weld, otherwise you will get a dirty weld and it will still leak.
for best results, tig weld is the way to go.
Old Jul 22, 2018 | 01:32 PM
Yusuf125's Avatar
Yusuf125
Thanks, yes obviously cleaning is important. I’ll pull it off this week.
Old Jul 22, 2018 | 01:38 PM
PupnDuck's Avatar
PupnDuck
+1 for tig although you could mig weld it, but cleanliness is EVERYTHING. Drop the pan, clean with some kind of solvent then hot soapy water before welding. JB Weld would be a waste of time on a leaking, oily pan. Oh, and you can get a brand new 77 Ford big block oil pan on Amazon for less than 65 bucks.
powerstroke1869
Jun 3, 2010 04:55 PM
rkymtnman30
Mar 15, 2009 02:25 PM
damirk
Dec 16, 2008 09:23 PM
Nitramjr
Aug 14, 2006 06:20 PM
covrace
Nov 17, 2003 05:00 PM
