Bronco II Ford Bronco II
Auto trans is slipping
Old Sep 22, 2003 | 02:59 PM
Bgrossenbacher's Avatar
Bgrossenbacher
The original Automatic transmission in my 90 b2 has starting slipping some when you first crank and go. It quits after driving a few minutes.
Any ideas on controlling this without a trans rebuild?
Old Sep 22, 2003 | 03:04 PM
1997ford5.0L's Avatar
1997ford5.0L
Try changing the fluid and filter. Alot of customers we have complain about slippage when the fluid is cold and none after it warms up.
Old Sep 22, 2003 | 03:06 PM
Bgrossenbacher
Is there an easy/obvious way to do this? is there a drain plug? where is the filter?
thanks
Old Sep 22, 2003 | 04:41 PM
knucklehead11's Avatar
knucklehead11
Good 'ole A4LD!
Old Sep 22, 2003 | 08:47 PM
Avanti's Avatar
Avanti
You drop the pan on the bottom of the automatic transmission to change the filter & get out some of the fluid. If this is all new to you get a Bronco II shop manual at an auto parts place.
Old Sep 22, 2003 | 09:08 PM
lewie's Avatar
lewie
Hey Bgrossenbacher,
Great advice from those above, however, If it were mine, I would not just change the filter and trany fluid. I would get the trany flushed. You can get this done at most any oil and lube shop. This would especially be necessary if you have had it stuck, the fluid could be "burnt." Remember that a slipping transmission is nothing to ignore or to belittle. Good Luck.
lewie
Old Sep 26, 2003 | 08:16 PM
MJB's Avatar
MJB
Don't forget to sniff the old fluid first. If it smells burned you'll not only flush the transmission but you will need a band adjustment. You can do that with a Inch Pound Torque Wrench.
Old Oct 2, 2003 | 07:20 PM
MJB's Avatar
MJB
And since you said it slips when it's cold, that tells me it needs a band adjustment.
Old Oct 20, 2003 | 07:48 AM
Bgrossenbacher
MJB
How/where do you adjust the 'band'?
thanks
Old Oct 21, 2003 | 09:20 PM
MJB's Avatar
MJB
If yours is an A4LD, on the drivers side of the tranny you will see the band adjustment bolts. Be sure you consult the shop manual before you do this.
Old Oct 23, 2003 | 05:46 PM
jclopezv's Avatar
jclopezv
Hey Bgrossenbacher, How did it come along? How much did you spend?
Thanks
Old Nov 3, 2003 | 07:51 AM
Bgrossenbacher
Finally drained the fluid and changed the filter this past weekend. So far not slipping... it's nice to push the gas pedal and actually have it go without racing the engine.
FORD didn't make this easy, did they...
I also replaced all four shocks with Monroe gasmatic's and the ride is less like an old truck.
dertyboy
1997 - 2003 F150
May 28, 2016 02:07 PM
Jay1234
22
Apr 13, 2016 09:11 AM
Americanmadeford
Feb 10, 2007 12:45 PM
jwrboss302
Nov 26, 2003 05:55 PM
GeneStoner
Jan 7, 2003 12:30 PM
