Overdrive and Towing Questions
Need some advice please. Just purchased a 2000 F-150 5.4L with 3.55 rear end. Towing my boat over the weekend (not sure of the weight) 19 ft. runabout over hills, I left the overdrive on while on the interstate. The transmission never downshifted out of OD. Am I doing the right thing? The manual is not much help. I don't want to harm my truck. I love it. This is our first long ride. I turn the OD off when I get on the backroads going to the lake. Any Advice.
Thanks,
Donnie
Thanks,
Donnie
Most manuals say downshift if the tranny starts to hunt gears. If your tranny didn't try to shift and if you weren't lugging it, I would think it was OK.
My 460 with E4OD hauls an 8,000# trailer. It only downshifts on long or steep hills. been hauling with this truck for about 30K miles so I would guess driving in OD is OK for me.
Jim Henderson
Jim Henderson
Its ok because the torque converter should be locked and nothing slipping causing any heat build up. Drive(3rd) is still the strongest gear in the tranny because using 3rd locks the ring gear to the planets and causes everything to spin as a unit, producing a 1:1 ratio
I dug this topic up from a couple pages back. If I understand correctly, it is acceptable to trailer in overdrive as long as the transmission is not shifting in and out of OD. For a relatively flat highway it should be acceptable to keep it in OD as long as it’s not shifting too much. If there is a series of hills or an incline drop it into drive until the road levels out.
Just wondering if I was getting all of this right because a few buddies told me to always trailer in drive and never overdrive. They’ve been wrong before so I figured I’d get some more input.
OD while towing
I had a similar question about when to use the OD on/off feature. In Motor Trend's Truck Trend magainzine (Sept/Oct 02 edition), it states that for GM's (not sure if this applies to Fords or not), that "5th gear is fully functional in the Tow/Haul mode, but it may require higher speeds before engagement." This seems reasonable, such as when you're towing and going down a flat interstate.
I guess my question is, does the same apply to Fords, specifically '02 Ford rangers with a 5 speed auto tranny? It seems like it should. The goal after all is to keep from shifting as frequently and building up heat isn't it. And if road conditions allow it, why not tow at 70, where OD would be beneficial if for no other reason than to use less gas.
Everyones thoughts would be appreciated.
