I read yesterday about the magnet should be centered on the CPS. I can't find it now but here is a picture of one of mine.
I guess I can remove the silicone and center the magnet and re-silicone.
Any opinions are and will be appreciated.
Thanks, Marvin
EDIT AGAIN--------------After removing all the silicone it looks as if it can't be moved. Seems to be inside molded plastic.
2001,F250, 7.3, Super duty http://
Reason: Link not working
I tried to crank the truck today and nothing, just turned over fast as usual. The RPM dial did register and continued to register as long as I was cranking. I believe the RPM needle moving is an indication that the CPS is OK-------Is this correct?
2001 F250 7.3
Marvin
Yes, tach is driven by cps.
If you have obd2 dongle and torque pro check that hpop pressure can reach 500psi, the threshold pressure to crank.
Just as a test for a bad ICP sensor unplug it and try to crank.
Make sure the oil isn't low also no oil up top = no crank
