Hellwig Sway Bar Owners
Old Jul 19, 2018 | 07:49 PM
dethpulse's Avatar
dethpulse
I am finishing my Hellwig install - my 03 7.3 never had a sway bar but the install was relatively straight forward until the end. The instructions say to make sure the sway bar is level with the ground when the truck is sitting on its suspension (not jacked up). I took out a small magnetic level and began to set the end links, but even at their shortest, the end links are too long to allow the sway bar to be absolutely level with the ground. Is this normal?
Old Jul 19, 2018 | 08:26 PM
wpnaes's Avatar
wpnaes
Yeah that’s fine.
Old Jul 19, 2018 | 08:29 PM
dethpulse's Avatar
dethpulse
Thanks! I'll torque everything down then .
Old Jul 20, 2018 | 06:11 AM
wpnaes's Avatar
wpnaes
If your body mounts are aging like mine, don’t be surprised to hear more noise from them and the occasional pop over uneven surfaces.
Old Jul 20, 2018 | 09:46 AM
thor363's Avatar
thor363
I'd say it's normal IF you picked the right bar for the amount of lift you have. I needed the Hellwig 7878 for the 4x4 Ex based on the options on the actual Hellwig site.
Old Jul 20, 2018 | 10:20 AM
dethpulse's Avatar
dethpulse
I don't have any lift (stock height) so I ordered the 7643, which I think is the correct part # for no lift.
PSUhoss's Avatar
PSUhoss
Deth - I had the same experience with mine and contacted Hellwig. They asked for photos and after reviewing them, sent me a shorter pair of end links. Awesome customer service.
Old Jul 20, 2018 | 10:40 AM
jasoncw's Avatar
jasoncw
Better than I had. Somehow my Ex must be different than most, as my U-bolts for the lower shock mounts were a smaller diameter than the U-bolts they supplied. They asked me to send pics, I did, and they told me to drill out the lower mounts to accept their larger U-bolts...
Regarding the original question, that sounds normal with stock height springs. I put C codes on mine, which raised it about a couple inches, and I have the links adjusted almost all the way in to make it parallel.
Old Jul 20, 2018 | 10:44 AM
dethpulse's Avatar
dethpulse
Hey - GREAT tip PS. Karma for you (if I have any left as a new guy).
Old Jul 20, 2018 | 11:12 AM
thor363's Avatar
thor363
I thought I was missing a lock nut from my Hellwig kit, and they sent me a complete set of plates, bolts, and nuts. They called me right back actually. I started with an email to customerservice@hellwigproducts.com
PM me and I'll give you Kevin's number at Hellwig. He was good to deal with
Old Jul 20, 2018 | 11:26 AM
thor363's Avatar
thor363
PM replied.
Old Jul 20, 2018 | 11:52 AM
thor363's Avatar
thor363
BTW: if you have a smart phone and your vehicle is on level ground,, you can use the 'Clinometer' App to find your level on the bar.
NMSU_RRAggie
Dec 11, 2015 07:48 PM
bobbyrjw
Apr 27, 2011 11:43 PM
B/B ford
Mar 13, 2008 08:43 AM
fordman311
1997 - 2003 F150
Feb 22, 2005 03:51 PM
n2racin
Jun 12, 2002 06:04 PM
