Sway bar dissconnects
I don't know what you mean by more flex but you would gain more wheel travel if you disconnected the sway bar as the sway bar can only twist so far. If you remove it...the truck will have more body roll on the highway when cornering. The ride will soften somewhat too.
I think all you need to do is just unbolt everything and remove it. Just don't disconnect the end links....do that and you may be asking for problems.
Someone will correct me I'm sure.
Obviously not for fords, but it was the first link I came to. I was jsut tossing this idea up in the air, doubt i will do it cause of the $$:
http://www.jksmfg.com/quicker_disconnectsTJ_XJ_ZJ.htm
i think you're going to have to copy and paste that instead of just clicking link
It doesn’t so much give you more wheel travel as it dose more articulation. The purpose of the sway bar (aka anti roll bar) is to stiffen up the body by not allowing either side to travel up or down independently too much. By disconnecting the links each wheel will be able to travel it’s full length independently of each other. Ie one wheel could be up on a rock and the other in a ditch but both touching the ground getting traction.
I think you can just remove the rods on the end of the sway bar to disconnect it, haven’t really looked at mine though. But theres no way I would ride down the road with it unhooked. You’d feel like it was gonna roll over at the slightest curve.
astarner74
04-05-2011 02:24 PM
southbound35west
03-17-2007 08:19 PM
