6.2L V8 Discuss the 6.2L V8
MPG Differences when using different tire size?
Old Jul 19, 2018 | 01:45 PM
K&Y-TIMEOFF's Avatar
K&Y-TIMEOFF
F250 6.2L CCSB ... what happens with MPG & towing ability between 18" & 20" BFG KTO2's ?
Cheers,
Ivan
Old Jul 19, 2018 | 01:57 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Whenever you increase the rolling diameter of a tie it will affect both mileage and towing, the bigger the diameter the more power it takes to turn it over so the mileage will go down along with the towing.
Denny
Old Jul 19, 2018 | 07:23 PM
Chuck's First Ford's Avatar
Chuck's First Ford
Correct to a point...
diameter of inflated tire.. is the issue
a tall profile 18 and a low profile 20 could almost be the same... otherwise as stated above.
Old Jul 20, 2018 | 08:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Post the entire tire size, for example, 285/75R16
Old Jul 20, 2018 | 09:46 AM
acadianbob's Avatar
acadianbob
It's not diameter but also the weight of the tire/rim. More weight, more effort to get it rolling.
Old Jul 20, 2018 | 10:55 AM
cattaco's Avatar
cattaco
Yeah honestly with 4.30's if you increased your tire size and didn't increase weight much, you might actually get better highway mpg's. But you will usually lose mpg's when increasing size.
yosemitesamiam
Jun 4, 2013 01:28 PM
gopher2
18
Oct 10, 2008 10:51 AM
Sethw3
2004 - 2008 F150
May 9, 2008 03:32 PM
CougarXR02
1983 - 2012 Ranger & B-Series
Nov 10, 2007 03:50 PM
95frd
Jan 20, 2007 04:01 PM
