Emergency brake cables
Old Jul 17, 2018 | 10:10 AM
Mike8623's Avatar
Mike8623
1996 f250 7.3 5 speed
OK guys my ebrake isn't working well, crawled under the truck and the cables appeared stretched and slack.....do you just replace the cables (it looks like you just slip them out of the coupler) or how do you go about adjusting them?
Old Jul 17, 2018 | 10:25 AM
97-psd's Avatar
97-psd
You can’t adjust the cables. It is a balancing act within the brake drum.
You essentially reset the brake shoe adjusters when you put a new cable on.
i have seen some people build a cable tension device out of all thread and flat plate steel but if everything is setup right it should not be needed
tsevrens
31
Feb 7, 2023 10:14 AM
1993 ford
Jul 6, 2017 10:55 PM
cub102
Jun 11, 2015 10:01 PM
JUGGALO_6
1997 - 2003 F150
Aug 17, 2007 02:47 PM
MikeGV
Feb 6, 2005 09:43 PM
