My 1973 F250 CS has rear air shocks on them. I plan on replacing all 4 shocks in the near future. The question is: do I need to replace the air shocks with air shocks?
i don’t plan on doing any major towing. I have reached out to folks at Monroe and Rancho: both gave me different answers so I figure I would throw it out here.
It is clearer and clearer to me that the previous owner did a fair amount of towing. I dont think the shocks were for a stance look. With that said, I dont plan on using this for a lot of major towing.
If I go back to normal shocks, I’m thinking KYB Gas-A-Just on all 4 corners (since KYB does not make MonoMax for my year and model)
This is what I've got on the rear of my truck. Love them. The ride is very nice as compared to lower quality shocks.
I run the "better" gas shocks from AZ. Probably similar to what is posted above. They really helped ride and reasonable cost.
Air shocks or spring assist shocks can help level the ride running heavy or towing but you do not need them in your application.
FWIW my F250 rode like a buckboard with worn and broken OE springs, overload springs and dead shocks. Ditched the overloads, replaced the originals and new shocks as above and different truck. Rides great and still handles 2,500# when it needs to.
I was able to score the KYB's for $119 shipped so thats whats arriving. I also ordered some MOOG variable rate springs for up front, and all new bushings for up front, the cab, & rear sway bar from Energy Suspension.
I will eventually get to the leaf springs. I will need to take action on them sooner than later as I noticed on of the leafs has a crack.
People use air shocks for a poor load helper, to fix sagging suspension or for "stance". They aren't really built to handle those duties long term though, they are junk.
