Top trim installation help
Old Jul 15, 2018 | 12:28 PM
JBMorrey's Avatar
JBMorrey
so I have finally gathered up all of the trim pieces to do the top middle trim on my 1975 F100, running into an issue with the front fender trim at the very top close to the side turn signal. How do you get to the other end to screw on the nut to attach it? I have little fingers and the access from the front turn signal it a metal hole that I can’t access well enough, hard to fit my fingers in the side turn signal hole as it’s too narrow and from underneath, I cannot really see and eve by feel, I can’t hold the nut properly to start spinning it. Any ideas regarding suggestions are appreciated.
james
Old Jul 15, 2018 | 12:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by JBMorrey
so I have finally gathered up all of the trim pieces to do the top middle trim (upper body side mouldings) on my 1975 F100, running into an issue with the front fender trim at the very top close to the side marker lamp.
How do you get to the other end to screw on the nut to attach it? I have little fingers and the access from the front turn signal it a metal hole that I can’t access well enough, hard to fit my fingers in the side turn signal hole as it’s too narrow and from underneath.
Upper body side mouldings: With or without vinyl inserts?
Old Jul 15, 2018 | 12:58 PM
JBMorrey's Avatar
JBMorrey
Sorry, it’s the thicker molding.
here is a pic as to where I am at.
Old Jul 15, 2018 | 01:04 PM
flatbedfordguy's Avatar
flatbedfordguy
Have a buddy use a pair of long needle nose pliers to hold the nut as you insert the screw, this is less weird than it sounds lol.
Old Jul 15, 2018 | 03:05 PM
JBMorrey's Avatar
JBMorrey
Yea, I finally changed out the “hand tight” nut for a regulat nut and used a 1/4” extension to tighten the nut slowly but surely.
thanks for the recommendation, that sparked my thought process to figure it out.
james
Old Jul 15, 2018 | 05:55 PM
lafermedavid's Avatar
lafermedavid
yea ,I been thinkin Im going to put that molding on before I install my fender,,,,,,,thinking for about a year or more,funny how that is
Meridian_Mike
Jan 25, 2019 01:40 PM
axidjw
North Carolina Chapter
20
Jun 3, 2016 06:30 AM
79F250isalive!
Feb 27, 2015 05:59 PM
66CustomCab
Oct 29, 2014 07:02 PM
LONCO
Apr 23, 2003 10:14 PM
