1987 fuel pump
Old Jul 18, 2018 | 08:18 PM
twwtruck's Avatar
twwtruck
Ok I will check volts on relay again and tap inertia switch. And there is 12volts of power to coil when key is on.
Old Jul 19, 2018 | 04:11 PM
87 XLT's Avatar
87 XLT
From your symptoms it looks like the ignition switch is OK. Try this simple test, turn the key on & ground the "fuel pump" pin in the EEC4 test connector. The connector is hanging at the end of it's wires under the hood near the heater blower motor. When you ground the pin you should hear the pump relay click & the pumps should run. This tests 90 percent of the fuel pump circuit, but not the ECM. If the pumps run when you do this the ECM is a suspect. If the pumps dont run the ECM is probably OK.
Old Jul 20, 2018 | 04:54 PM
twwtruck's Avatar
twwtruck
Well I tested number 4 atleast of the diagram I looked up is correct and nothing happened
Old Jul 20, 2018 | 04:59 PM
twwtruck's Avatar
twwtruck
Also I don't have power to both sides of the relay now
Old Jul 20, 2018 | 05:04 PM
twwtruck's Avatar
twwtruck
Also I do not have the exhaust bolted up yet would that cause any kind of grounding issues? And I have no power to inertia switch
Old Jul 21, 2018 | 02:37 AM
87 XLT's Avatar
87 XLT
The positive battery cable & 4 fuse links are connected together at the starter relay, one of those links feeds 12 volts to the fuel pump relay on a solid yellow wire. The 12 volts should be there whether the key is on or off. If this is how you have it wired maybe the link is blown
The exhaust wont cause a problem
A couple grounds to check are from engine to fire wall and negative battery post to the sheet metal beside the battery.
Old Jul 21, 2018 | 08:42 PM
twwtruck's Avatar
twwtruck
So grounds are there and hooked up. I will have to check that yellow wire for power. I ran a hot wire to inertia switch and pumps will run. And cool has power to it and out of it but is not firing like the signal from distributor is not being sent.
Dean Ledgerwood
Aug 5, 2016 12:02 AM
Whitey Ford
1978 - 1996 Big Bronco
Oct 14, 2015 08:00 PM
xfordtech
1997 - 2003 F150
Apr 21, 2006 11:46 AM
bronco2va
Bronco II
Jan 15, 2004 12:14 PM
87' POS Ranger
Nov 4, 2003 08:57 PM
