need help diagnosing a no start fuel system problem
Old Jul 14, 2018 | 09:36 PM
court1100f's Avatar
court1100f
Ok what's already been done. New Fuel tank and low pressure sending unit, New Fuel Tank Selector Switch,New Fuel Pump Relay,New inline high pressure pump.
Ok. the problem it fights to start and once it does it sputters and with me constantly pumping the gas it barely and I mean BARELY runs at 600-1000rpm for about 1-2 minutes and dies..........What else could I possibly do to it to get it running I'm at a loss
Also the fuel filter was previous replaced
Old Jul 15, 2018 | 09:50 AM
rla2005's Avatar
rla2005
What is the fuel pressure at the test port on the fuel rail? New parts does not necessarily mean good parts.
Old Jul 24, 2018 | 10:12 PM
JerryGarcia047's Avatar
JerryGarcia047
Check to see if you have bent push rods. I've owned a couple trucks that I purchased as projects, and they would run poorly and for short periods of time. I thought it was out of time, bad starter and pump. It ended up being bent push rods. This may not be the case with you if your engine
turns freely, so best wishes.
Shawn Paris
Aug 2, 2016 10:56 PM
cyclist7531
1983 - 2012 Ranger & B-Series
Apr 29, 2011 11:22 AM
dr strangelove
Sep 9, 2010 04:13 PM
szpieleusa
6.4L Power Stroke Diesel
Mar 30, 2009 08:26 AM
lnistico
1997 - 2003 F150
Feb 9, 2007 05:25 AM
