Adjustment for door handle
Old 07-13-2018, 12:41 PM
sandymane's Avatar
sandymane
sandymane is offline
The handle on my 91 F250 driver door has to be pulled WAY out to open the door from inside. Before I take the panel off, is there an adjustment for it to make the pull shorter? Thank you Sandy
Old 07-13-2018, 12:54 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
Received 1,365 Likes on 1,078 Posts
It’s been a while since I had my door panel off but I believe the end of the rod can be adjusted where it clips into the latch
Old 07-13-2018, 12:56 PM
sandymane's Avatar
sandymane
OK, thanks for the info. I'll see if anyone can verify this or offer any other info before I pull it. Thanks again. Sandy
Old 07-13-2018, 01:39 PM
mountainkowboy's Avatar
mountainkowboy
mountainkowboy is offline
Your bushings/lock clips are probably worn out...there cheap and available.
Old 07-13-2018, 01:43 PM
sandymane's Avatar
sandymane
Will check that out when I pull it. Thank you Sandy Anyone else?
Old 07-13-2018, 02:35 PM
R&RFord's Avatar
R&RFord
R&RFord is offline
The handle assembly can have problems, the cable can stretch and the sheet metal where the handle assembly mounts can have problems. You will see how it works when you open it up and you may be able to tweak a few things, but when this occurred on my truck it I lived with it until I had another reason to take the panel off, which in my case was the power door lock actuator died. The latch was also becoming a pain so I replaced the door latch, handle assembly and cable, interior door handle, and lock actuator all at the same time. My feeling was and is, I hate cramming my hands and arms into the door as well as risking breaking the plastic trim so I don't take the door panels off until I need to. When I do I try to do any work needed or that I judge will be needed in the near future.
It was kind of a pain messing with the latch as there are so many actuating rods but it wasn't the worst thing I have ever messed with.
Old 07-13-2018, 03:11 PM
sandymane's Avatar
sandymane
Exactly why I asked before I started looking inside. I have heard about the cable stretching. With only 86K on it I hope it will not be that. I'll see if anyone else offers advice and then take it off tomorrow and check out the help ideas I have received so far. Thank you Sandy
Old 07-13-2018, 04:04 PM
R&RFord's Avatar
R&RFord
R&RFord is offline
I guess for me, I didn't want to band aid fix it and then have to mess with it again in a few months or even a few years. So I just replaced it with an oem part which I expect to give 15 to 20 years of faithful service.
The passenger side door sees so little use is still like new mechanically, while the driver side is like new because of all the parts I have replaced. The only thing I expect to go out on the other side is the door lock actuator as it gets the same amount of use as the other side.
Old 07-14-2018, 02:14 PM
My4Fordtrucks
...the cable can stretch.....
I did not believe this to be correct so I pulled the door panel on my ‘89 since it takes less than 5 minutes to do. It is actualted by a rod and not a cable. According to your profile, you have a ‘94 so that would apply in your case. LMC lists the cable for ‘92-96 trucks.
Old 07-14-2018, 02:54 PM
sandymane's Avatar
sandymane
Mine is rod actuated. I saw no adjustment available. Handle innards were tight but squeaked and moaned bad and I lubed everything. Door works like butter now and a slight pull opens it. Thanks to those that replied. Sandy
Old 07-14-2018, 08:30 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
91 and older trucks are rod. 92+ are cable.
I would bank on the plastic clip being worn out. Simple 10 min fix
pwjackson42
04-10-2014 06:11 AM
Hart 2000 EB AWD
1997-2006 Expedition & Navigator
09-16-2004 03:24 PM
aerostarinNorway
Aerostar
06-25-2004 12:16 PM
aerostargal
1997 - 2003 F150
05-31-2004 04:27 PM
RickMc
Paint & Bodywork
03-29-2003 05:15 PM
Quick Reply: Adjustment for door handle
