please help...Starter won't stop spinning
Old Jul 12, 2018 | 11:26 AM
nickniles's Avatar
nickniles
So I traded my motorcycle for a 99 f250 w/ the 5.4 Triton. The a/c was out so I dropped 900 bucks to have a whole new kit put in. Drove it less than 5 miles to a convenience store and when I came back out all it did was click when I turned the key. Had the mechanic that did the ac come look at it. He said it was either the starter relay or starter but he would be able to find out for sure if I could get it to his shop. I opted to do it my self since I just spent so much. I changed the relay since it's cheaper and it still did the same thing. Had it towed to my house. Changed the starter and it started. Shut it off and started it again just to check. Noticed a sound and smell and realized the starter was still spinning. Shut it off and everything stopped. Tried it again and the starter just spins without turning the engine over. Please help. I'm no mechanic, but have a basic idea how things work and how to change stuff out.
Old Jul 13, 2018 | 10:27 AM
nickniles's Avatar
nickniles
Help
So day 2, 2nd starter. Same situation except now it just clicks when i try to start it versus spinning on the last one 😡😡🤬🤬🤬😡😡😡😡
Old Jul 13, 2018 | 11:05 AM
projectSHO89's Avatar
projectSHO89
1. Make sure you didn't put the starter cable on the "wrong" post when you replaced the relay.
2. Disconnect the small wire from the relay and see if the starter disengages.
3. If the wiring is correct and the starter still activates with the small wire disconnected, assume either the "new" relay is defective (normally open contacts are welded together internally) or the "new" starter is defective or mis-wired.
Old Jul 20, 2018 | 09:48 PM
nickniles's Avatar
nickniles
You nailed it
So after 3 starters, I realized that I did in fact have the cables on the wrong posts on the relay.
Old Jul 20, 2018 | 09:50 PM
nickniles's Avatar
nickniles
Thanks
Thanks for the advice.
Old Jul 21, 2018 | 05:39 AM
projectSHO89
Don't ask me how I knew that....
taylerallen6
1997 - 2003 F150
Jun 21, 2016 06:45 PM
leforrest
1997 - 2003 F150
Jan 24, 2013 07:34 PM
ktbrach7
Dec 10, 2012 05:24 PM
PLatreille
Jan 29, 2007 08:27 PM
Sweetred95ta
Sep 20, 2006 04:41 PM
