Best Saginaw P/S BRACKETS
Hello all. I'm upgrading to a Saginaw P/S pump and have an 80's bracket from a Ford Van with a Sag pump. I've seen the cast aluminum brackets from later model with the Sag pump and I liked the look. Does anyone have a pic of their engine with that type of bracket mounted?
Thanks.
Thanks.
Yep they changed the bracket design when they went to the serpentine belt & EFI. But that worked out for me because I prefer the serp. belt setup. I'm converting my engine over to the serp. belt Just need to fab up a custom alternator bracket for a little more header room and swapping to a 3G set up. The main down side to the serpentine set up is the water pump isn't quite as good as the older design.
fordf350camper
05-12-2013 09:10 PM
73FOMO
05-09-2009 02:24 PM
79-400-POWER
11-02-2007 03:29 PM
