Sponsored by: Real Truck
Diagnosing Engine Knock
Old Jul 11, 2018 | 08:38 AM
Rick Ammons's Avatar
Rick Ammons
I have what appears to be a lower end knock on my '05 F250 6.8L and have been told I can rule out rod knock by disconnecting each plug to determine which cylinder has the knock. Is it better to pull the connector from the coil pack or disconnect each injector instead? Trying to rule out rod knock before moving on to flex plate.
Old Jul 11, 2018 | 10:20 PM
fordmerc's Avatar
fordmerc
Disconnect injector.
Old Jul 12, 2018 | 03:19 AM
Chuck's First Ford's Avatar
Chuck's First Ford
as stated,,, Disconnect injector. but the rod knock may not stop .. but the "TONE" of the knock will change...
doing the spark plug wire... can cause flash over... and damage electronic stuff.. ( MAYBE )
best way is to remove the oil pan.. and each rod cap. ( one at a time )
Red454sedgwick
Feb 3, 2015 11:59 PM
berg87
3.8 & 4.2L V6
Jul 4, 2008 07:19 AM
Hellonwheels
Apr 15, 2008 04:09 PM
timothy47129
Oct 16, 2005 01:37 PM
Pick-up Line
Jun 22, 2003 08:28 AM
