is this normal ?
Old Jul 8, 2018 | 04:23 PM
jsmithis101's Avatar
jsmithis101
is this normal ?
Start looking over the truck a little more, I notice the rear passenger door isn't flush with the cab, is that normal ? This is a 2018 F150 Supercrew long-bed.
Old Jul 8, 2018 | 06:41 PM
srb1194's Avatar
srb1194
In my opinion, no. Mine isn't like that.
Old Jul 9, 2018 | 05:28 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
This had been an issue when the 2015's were rolling out. I thought Ford fixed it.
Old Jul 9, 2018 | 08:26 AM
storage_man's Avatar
storage_man
This looks like it maybe a common problem. My 2018 has the same issue (Mostly the rear passenger side). I took it in to the dealer, they agreed that it needed re-alignment. They did caution me on having it fixed which may result in leaks (that's why I said it maybe a common issue). They re-aligned it, they did check for leaks, its ok but it still isn't flush as front doors are. I'm trying to ignore it now along with the Dash board !
Old Jul 9, 2018 | 10:59 AM
jsmithis101
Toke it in this morning, scheduled to go back on Thursday to be "adjusted" I was also told it may cause the door to leak after wards. If it does i'll have to see what my options are after that, we pay good money for these trucks we shouldn't be expected to just "deal with it".
Old Jul 9, 2018 | 12:55 PM
doyall's Avatar
doyall
'18 STX SCrew ... none of mine are what I would really call flush but the rear passenger side is the worst as well.
Old Jul 9, 2018 | 01:13 PM
jack orchard's Avatar
jack orchard
Not normal, but it is common.
Old Jul 9, 2018 | 02:08 PM
GlueGuy's Avatar
GlueGuy
Left rear and right front corners are proud on our Supercrew. I roamed around the dealer's lot back in 2015, and I would estimate that more than half of the supercrews had this issue. Some more than others.
My wife's 8 year old Tacoma is perfect, or as close to perfect as you can tell without a micrometer. Our previous Tacomas and Tundras were also perfect.
Old Jul 9, 2018 | 03:38 PM
CR172's Avatar
CR172
Ford's fit and finish could use some work. Had to take the wife's Edge back for door alignment. Passenger side was way off. Haven't really noticed anything with my scab.
Old Jul 9, 2018 | 08:24 PM
onug's Avatar
onug
I’d noticed the bad alignment on the tailgate, but not the doors. I just looked and my right side rear door is like that. Running my finger from the bottom to the top on the seam you can really feel the difference. Sometimes the door is wider, other times the cab sticks out. Strange. Aluminum might have more sprig-back after forming, but Ford should have figured it out my now.
Looks like one part was spec’d in Metric and the other in Imperial units.
Old Jul 10, 2018 | 01:10 PM
GlueGuy's Avatar
GlueGuy
I think the "indent" that runs across the top of all 4 doors is by design. Probably some aerodynamic thing. I've seen it on all the supercrews that I've looked at.
Old Jul 12, 2018 | 06:10 AM
johnday's Avatar
johnday
My SCab right rear door is like that. Don't plan on doing anything about it.
Old Jul 12, 2018 | 10:56 AM
jsmithis101
Dealer was able to fix the door alignment in a couple minutes, now i need to run it through a car wash to see if it leaks
Old Jul 12, 2018 | 12:11 PM
Wiggums's Avatar
Wiggums
I made sure to look for that before buying mine!
ImSoQuazy
15
Jul 25, 2022 07:43 PM
Spoojr
Feb 2, 2019 04:03 PM
lavatan
Jan 14, 2012 06:04 AM
Ford Fx4
2004 - 2008 F150
18
Apr 3, 2009 01:30 PM
Red Star
Ford vs The Competition
25
Feb 7, 2007 07:30 PM
