Hanging Door Help
Old Feb 18, 2016 | 01:29 PM
ImSoQuazy's Avatar
ImSoQuazy
Hanging Door Help
Hi FTE Friends,
I believe with your help, I can accomplish what I've set out to do - have a better fit on my doors.
It's been struggle, but I don't dwell on all the things I feel, instead I'm glad I do...
In short words, the 351W purrs, ROARS and drives better than new. Tranny, is impeccable. Rear end is working as designed (though I had the gears modified).
Recently installed the Mustang II upgrade (though shaky on results until it gets aligned (shimmed) and all that jazz.
What's left? To have the doors aligned - AT LEAST better than they currently are - and re-install door rubber to keep noise and water out of cab.
So I'm reaching out to you -with visuals - with hopes that in return I can get a visual step by step process so that I can accomplish this without having to employ any further help (them are big hopes folks)
Here is where I'm at.
Doors are hung -- see picture sequences
I welcome all input.
Paul
Old Feb 18, 2016 | 02:18 PM
abe's Avatar
abe
I see nothing wrong with those doors. I would say they are well hung!
Here is a tip though. Put your weatherstripping on before you fine tune your doors.
Old Feb 18, 2016 | 03:47 PM
Don Vito's Avatar
Don Vito
You may need to tweak them I think I read on here at one point you just need to muscle them to where you want them (in another bend them, push on them etc ) Pretty sure I read that here. Seriously...
Old Feb 18, 2016 | 06:34 PM
Mervy49's Avatar
Mervy49
On my drivers side door I had to do what Don just described, the top right curve, I had to message the door frame out. And, the door itself at the top corner had to be tweeked in a bit. I wondered at times if the factory was out or whatever else.
Old Feb 18, 2016 | 06:47 PM
chad77's Avatar
chad77
Make your hinges adjustable.
Drill holes, tap, add bolts.
Or mid fifty sells.
Old Feb 18, 2016 | 09:00 PM
EFranzen's Avatar
EFranzen
I had some similar fitment issues and used a 2x4 and some muscles to tweak an issue with the upper frame not matching the opening.
The bottom of the passenger door looks to fit well, except the front bottom corner. It looks like it needs to be massaged with a plastic dead blow type bfh to have the radius match front fender.
Ernie
Old Feb 19, 2016 | 11:51 AM
ImSoQuazy's Avatar
ImSoQuazy
Thank you All for the input.
Chad, you're on to something... but as Abe mentions, doors are hung well enough. I understand the massaging however I may be a bit late in the game for that. So really, a good seal may accomplish what I'm after.
Off to purchase another set of rubber... Oh, so, besides M50, DCarpntr etc... is there anyone else who delivers good rubber for our trucks? Anyone heard or purchase from Steele Rubber Products?
Paul
Old Feb 19, 2016 | 01:16 PM
abe's Avatar
abe
I got my rubber weatherstrips and window rubber from Steele but that was 17 years ago. They do make a lot of rubber products.
Old Feb 19, 2016 | 04:00 PM
ben73058's Avatar
ben73058
Hey Paul,
We have the same issue with our '50. Passenger doesn't fit well after the new rubber was installed. I'll follow your example.
Ben in Austin
1950 F1
Old Feb 23, 2016 | 07:56 AM
ImSoQuazy's Avatar
ImSoQuazy
Abe,
Well then... That speaks volumes for Steele...
Are you still happy with the rubber?
Any advice for glue, technique and ll that..?
Paul
Old Feb 23, 2016 | 08:10 AM
abe's Avatar
abe
The rubber was good quality. Windshield and rear window rubber still great shape, no off coloring or cracking, etc.
I am not sure where I got my door weather stripping.... I am getting my truck repainted and am getting the hollow core rubber this time. Will get it from Mid Fifty. My doors didn't shut well at the bottom with the original style rubber.
Old Feb 23, 2016 | 08:11 AM
abe's Avatar
abe
Old Feb 23, 2016 | 12:30 PM
ImSoQuazy's Avatar
ImSoQuazy
Thank you Abe
Want better fit myself too!
Old May 22, 2021 | 12:31 AM
maples01's Avatar
maples01
I need rear door gaskets for my 89 E150, LMC doesn't have it, anyone have a source, and a doghouse gasket too.
The gaskets I put on my 73 glued on, I bought the adhesive from the parts store, it bonds quick so it doesn't allow adjustments, but I like it better than the double sided tape stuff.
Old Jul 25, 2022 | 02:10 AM
Bullitt65's Avatar
Bullitt65
6th Gear
Hey Mickabout I really like your B100, I sent you a message. thanks
