It finally happen today ! - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150
Old 07-10-2018, 01:06 PM
storage_man's Avatar
storage_man
storage_man is offline
storage_man is starting off with a positive reputation.
My F150 will be 11 months old later this month. Today I had a chance to check out my wiper blades & squirts. It rained yesterday afternoon first time in 11 months in the greater Phoenix area, but I was home already and the truck was in the garage. But this AM, it rained again and I can now attest that my wipers seem to work just fine !
Old 07-10-2018, 08:25 PM
onug's Avatar
onug
onug is online now
onug has a great reputation on FTE.onug has a great reputation on FTE.onug has a great reputation on FTE.onug has a great reputation on FTE.onug has a great reputation on FTE.onug has a great reputation on FTE.
LOL ....glad everything works. You donít use the washer fluid very often? I use mine almost daily in the morning. I hate a dirty windshield.
Old 07-11-2018, 07:13 AM
Terryd91
Terryd91 is offline
Terryd91 is gaining momentum as a positive member of FTE.Terryd91 is gaining momentum as a positive member of FTE.
yeah with the pollen and dust around here it's pretty much every drive they get used. Kind of why i have given up washing my truck in the non-salt months, 20 min later it looks just as dirty as it did before. My wipers are getting crunchy at 13 months though, not bad for OEM.
Old 07-11-2018, 09:25 AM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
GlueGuy has a good reputation on FTE.GlueGuy has a good reputation on FTE.GlueGuy has a good reputation on FTE.
This is funny. We get a lot more rain than Phoenix, but a paltry amount relative to other parts of the country. The issue for us is that we live on a relatively long gravel driveway (8/10 mile). So we get a lot of dust. I probably run the washers/wipers once or twice a week. In the winter (November - March), we will get some rain.
Old 07-11-2018, 09:38 AM
Beachums's Avatar
Beachums
Beachums is offline
Beachums has a good reputation on FTE.Beachums has a good reputation on FTE.
PSA, when replacing your wiper blades, go for the silicone ones. They are comparable to the high end Bosch in price, but last 3 to 4 times longer.
I put PIAAs on my 150 last summer and they wipe just as well as they did the day I bought them. They survived through ice/snow and the moderate heat of the upper midwest. Which is important when you have the rain sensing wiper system.
You won't find them at any auto parts chain, as the wiper game is quite lucrative for those chains. People coming in 3 to 4 times a year to put down 50 bucks for a product that uses little shelf space and has a high profit margin is something they want to protect.
Example Example
Old 07-11-2018, 10:09 AM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
I have read in a couple of places that OEM wipers will give the best performance. Any comments on that?
Old 07-11-2018, 10:15 AM
Terryd91
Terryd91 is offline
The stock ones on my truck have lasted longer than the expensive bosh ones on my jeep, they are parked right next to one another so they see similar conditions. I can probably get another month or two out of them is i clean them up some.
Old 07-11-2018, 02:07 PM
CR172
CR172 is offline
CR172 is gaining momentum as a positive member of FTE.
I'm still running the original wipers that came with the truck. Almost 3 years and 58K miles later they still work great. Wonder if the blades you get from the dealer are the same???
Old 07-11-2018, 04:10 PM
CuNmUdF250's Avatar
CuNmUdF250
CuNmUdF250 is offline
CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.
I’m in the Phoenix area as well and it doesn’t matter what brand wipers you have the heat and lack of moisture will render them useless when you actually need them. I’ve just gotten in the habit of having a new spare set in the vehicle and even then they are aged due elements.
Old 07-11-2018, 07:15 PM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
Originally Posted by CuNmUdF250 View Post
Iím in the Phoenix area as well and it doesnít matter what brand wipers you have the heat and lack of moisture will render them useless when you actually need them. Iíve just gotten in the habit of having a new spare set in the vehicle and even then they are aged due elements.
If you take the plastic "tray" they are packaged in, and turn it over like a bowl, then fill it up with a little aerospace 303. Let them soak at least an hour or so. Then store them wrapped in plastic, they will be very pliable when you pull them out.
Old 07-11-2018, 09:22 PM
CuNmUdF250's Avatar
CuNmUdF250
I’ll have to try that GlueGuy. Honestly rainfall is so minimal here that you could rely on the material just below the lil blade to get the job done in a pinch. However it has rained now for 3 days in a row now
Old 07-12-2018, 09:22 AM
Beachums's Avatar
Beachums
Beachums is offline
I also heard for rubber blades that a rag soaked with mineral spirits quickly wiped down the blade will rejuvenate the rubber. But if people are getting 3-4 years on stock blades,I wonder if they are even rubber. They may be silicone.....
Old 07-12-2018, 01:34 PM
storage_man
Denatured Alcohol also works good. Clean them once per month (wipe them down) and I was able on my old truck to go 6 years before they finally died.
Old 07-12-2018, 05:11 PM
JKBrad's Avatar
JKBrad
JKBrad is offline
JKBrad is a name known to allJKBrad is a name known to allJKBrad is a name known to allJKBrad is a name known to allJKBrad is a name known to allJKBrad is a name known to all
The factory blades on my truck lasted longer than any other aftermarket ones I've bought. Even the PIAAs. Next set will be OEM replacements. Not only did they last the longest, but wiped the best.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
