help
Old Jun 24, 2018 | 10:00 AM
volk67's Avatar
volk67
help
1972 f250, Starter just spins. New starter, new regulator. Are these starters shimmed. I did not install, so curious.
Old Jun 24, 2018 | 04:10 PM
Filthy Beast's Avatar
Filthy Beast
Ford did not use shims on the starters.
Did you get a starter for a manual or auto trans? I believe there's a difference in the length of the nose.
Old Jun 24, 2018 | 06:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If the OP's F250 has a 360 or 390, there's only one starter for A/T & M/T .. It's the same for 1965/71 FE cars, 1965/76 FE F100/350's.
But, if the truck has a 240 or 300 I-6, A/T starter is different than M/T starter.
If the starter drive lands on a spot where the flexplate or flywheel has chipped teeth, the starter will just spin, because the starter drive has nothing to grab onto.
Old Jun 25, 2018 | 01:45 AM
GaryKip's Avatar
GaryKip
Isn't the bendix responsiabil to engage the starter?
Old Jun 29, 2018 | 06:59 PM
JEFFFAFA's Avatar
JEFFFAFA
Yes it is. As long as there are good teeth on the flywheel to grab on too. As Bill referenced. The bendix drive is also made to lock one direction but free wheel in the other. Like the pedal cranks on a 10 speed bicycle. If the bendix is a cheap aftermarket made in china piece. it may not be locking. This would also cause the starter to just spin.
First, I think the OP should make sure the installed starter is the correct one. Post your tranny and engine size. And the part number label on the box.
Old Jun 29, 2018 | 09:48 PM
volk67's Avatar
volk67
Thanks for all input. I'll dig into this. Truck was originally a 6cyl, auto. Has been converted to a 390, 4sp.
I got some research to do. Thanks again
WaveyDavey1980
Apr 18, 2019 09:31 PM
codafisler
Dec 25, 2011 03:22 AM
74f2502wd
Dec 8, 2011 04:56 PM
toolebox1
Nov 9, 2005 11:51 AM
Crumm
31
Nov 21, 2003 10:22 AM
