15K cooling system maintenance
Old Jul 7, 2018 | 07:53 PM
fmuguira's Avatar
fmuguira
Guys at my tire shop were telling me that our trucks need 15K cooling system checks for keeping coolant at right PH levels or something like that.
Anyway i I don't recall having seen discussions on this and not good enough with technology to do extended searches. Could anyone comment on this and if it's factual and how expensive to have checked? (I m at 11K mileage wise right now) Also is there a warning/reminder light in our trucks for this?
Thx much.
Old Jul 7, 2018 | 08:05 PM
Xwild's Avatar
Xwild
check your manual.. i'm guessing there is nothing in there about cooling system maintenance at 15k.. Your tire shop guys are just trying to rid you of your hard earned money, and give you nothing in return.
senix's Avatar
senix
did you check your owners manual? Also at the time of purchase, Ford has in the past given owners a one page sheet that spoke about this, the type of coolant and recharge plus fuel filters.
Old Jul 7, 2018 | 08:39 PM
fmuguira's Avatar
fmuguira
Did check manual and it does speak to checking coolant at 15K miles or 600 engine hours but not specific on how to do it. Sounds like a kit with strips are needed. Thought some of our members might have personal experience checking themselves.
Guys at tire store are personal friends, they were just 'pointing out' this procedure. Currently don't do it themselves and said most guys go to Dealer. I personally like to do my own maintenance where possible and go to Dealer only when mandatory.
Thx
Old Jul 7, 2018 | 08:46 PM
Xwild's Avatar
Xwild
check coolant - at most, it's verify level is correct, and if you're feeling like it, get a coolant tester to verify temp rating. https://smile.amazon.com/Prestone-AF...-no-redirect=1
Old Jul 7, 2018 | 08:50 PM
senix's Avatar
senix
Attachment 261287I checked mine, using test strips from accustrip.
Here you go
File Type: pdf
Old Jul 7, 2018 | 09:02 PM
fmuguira's Avatar
fmuguira
Senix, thanks! Was it easy to check? Sounds like you didn't need the Ford coolant additive.
Will ll be interesting to see at what mileage / time most guys have to put in additive.
senix's Avatar
senix
http://www.acustrip.com/res/pss/PSS-R071.pdf
Old Jul 7, 2018 | 09:03 PM
senix's Avatar
senix
very easy to check, I have never added anything to mine.
Old Jul 7, 2018 | 10:32 PM
Truckie256's Avatar
Truckie256
Don't the Gasser use the same coolant as the 6.7L??? would think the strip test at 15k would apply to the 6.2L also correct me if I am wrong
Old Jul 8, 2018 | 06:17 AM
senix's Avatar
senix
All the new Ford vehicles use the same coolant now as the 6.7. My 2016 Taurus or my 2015 Lincoln don't call for any testing.
Old Jul 8, 2018 | 08:57 AM
Chinookman's Avatar
Chinookman
Does Ford use a HOAT coolant?
Should be good for 100k.
The old days of cavitation, impingement on the cylinder walls should be history; thus negating the need for coolant filters and additional maintenance.
Old Jul 8, 2018 | 09:08 AM
Busa 1 Dave's Avatar
Busa 1 Dave
Actually there is more testing on the new systems than the old. Every 15k test the coolant and changes in severe conditions for the oil burners flush and fill at 60k!!!. Additive can be added twice but no more which is determined during the 15k checks. Need to read your manual.
Old Jul 8, 2018 | 09:49 AM
crewzer's Avatar
crewzer
Lightbulb
6.2 scheduled maintenance includes checking coolant concentration using a refractometer at 15K miles.
6.2 and 6.7 engines use use the same coolant.
HTH,
Jim / crewzer
Old Jul 8, 2018 | 01:37 PM
Blwnsmoke's Avatar
Blwnsmoke
The truck will tell you when to check the coolant, dont worry about it till it tells you to check it. It is around the 15k-17k mark when it will alert you on the dash
