15K cooling system maintenance
Old Jul 8, 2018 | 01:39 PM
Blwnsmoke's Avatar
Blwnsmoke
Originally Posted by Xwild
check your manual.. i'm guessing there is nothing in there about cooling system maintenance at 15k.. Your tire shop guys are just trying to rid you of your hard earned money, and give you nothing in return.
So you are guessing, have no clue and telling someone who has a question an answer of them trying to take his money without you even knowing about it? Why even post?
Old Jul 8, 2018 | 01:46 PM
Redrockerstl55's Avatar
Redrockerstl55
Originally Posted by Blwnsmoke
The truck will tell you when to check the coolant, dont worry about it till it tells you to check it. It is around the 15k-17k mark when it will alert you on the dash
I’m at 26,000. I never received that alert on my dash.
Old Jul 8, 2018 | 01:58 PM
Busa 1 Dave's Avatar
Busa 1 Dave
13.
check coolant - at most, it's verify level is correct, and if you're feeling like it, get a coolant tester to verify temp rating. https://smile.amazon.com/Prestone-AF...-no-redirect=1
Good Lord Man you are so tremendously uninformed it hurts me to read this. Hope everyone will cross check this incorrect information.
Old Jul 8, 2018 | 02:10 PM
Blwnsmoke's Avatar
Blwnsmoke
I know the 17+ have a different display but would be very surprised that Ford would change it.
mine triggered 2 days ago, I believe this is the 3rd time. Hmmmm
Old Jul 8, 2018 | 02:26 PM
crewzer's Avatar
crewzer
Lightbulb
Originally Posted by fmuguira
Did check manual and it does speak to checking coolant at 15K miles or 600 engine hours but not specific on how to do it....
There's a fairly detailed write-up on how to check the 6.7's coolant concentration and inhibitor strength in the OM (ref 3rd printing); see pages 336-339.
HTH,
Jim / crewzer
Old Jul 8, 2018 | 03:21 PM
Busa 1 Dave
I certainly hope that this will help some of the uninformed on this subject matter puts in perspective:
http://www.powerstrokediesel.com/doc...nformation.pdf
Old Jul 8, 2018 | 03:27 PM
Truckie256's Avatar
Truckie256
http://www.powerstrokediesel.com/docs/Coolant_Information.pdf
Link above doesn't work....
By the time I buy test kit and additive... Probably easier to just buy concentrate and distilled water and change it out and be sure it's good to go...
Guessing dealer wants the price of a test kit to test it. Then more for additive.
So much for long life....
Old Jul 8, 2018 | 03:51 PM
69cj's Avatar
69cj
Some dealers will check it for free and some not.
Old Jul 8, 2018 | 04:05 PM
Busa 1 Dave
Does now fixed it---not your copy here but on my post... Was picking up the smiley as part of the address
Too your point I will probably just change it out every year... About 20k to 25k for me.
Old Jul 8, 2018 | 05:43 PM
Painted Horse's Avatar
Painted Horse
This is a painful thread to read. I mean so much has been discussed on this in past threads, It scares me to think folks are still asking these kind of questions and getting the answer some gave.
2011-2016 trucks pop up a Check Coolant light around every 15,000-17,000 miles. Not sure about newer models.
Test kits used to cost about $80 but did 10 test. With two coolant systems, that means you get 5 total test.
People who don't drive a lot will not get the use of the full kit. It will expire out.before they use all the strips.
There are several test involved in testing your coolant
1st for freeze protection.
2nd. for Nitrite Contamination ( if you add the wrong coolant you have contaminated your coolant)
3rd for Reserve Alkalinity
and last for Corrosion Inhibitor level
If you failFreeze Protection or Nitrite Contamination Flush and refill with new coolant
If you fail the Corrosion Inhibitor. You can add VC-12 ( 48oz in the Primary system and 12 oz in Secondary) You can add this twice during the life of the coolant before you need to flush and refill
per the 2011 SuperDuty Workshop Manual Coolant should be at ambient temps when you do the test. I don't know how important that is since most dealers pull test of hot coolant.
Dealers have different programs, Some will test the coolant for free. Other charges enough that you want to get your own test strips.
I've owned a 2011, 2015 and now a 2017 truck. I checked the coolant every time the light came on with my 2011 truck and I added the VC-12 at 75,000 miles and changed it at 105,000
In my 2015 truck, I just added the the VC-12 at 50,000 and change the coolant at 75,000 because I tow a lot and figured it fell up Severe Service.
Remember you have two coolant systems, Both need to be checked.
If Nobody has every added anything to your coolant. The chances of the Nitrite failing are slim. You fail this test if somebody tops off your coolant system with the wrong type of coolant.
OAT antifreeze coats the engine part to prevent corrosion. If your coolant level drops and air can come in contact with internal engine parts, You will see corrosion. hence it's important to keep the coolant system full to prevent air from getting into the system.
Old Jul 8, 2018 | 06:27 PM
Chinookman's Avatar
Chinookman
Wow little did I realize how much has gone into this!
The OM for the Tundra was every 5 years check it.
So I'm thinking well maybe all these vehicles really have gotten better. Sigh
Well, Guess I'll have to finish up on reading the OM now who knows what other lil treasures are in there that I took for granted.
So thanks for the schooling. Hey have a great last of the weekend yah'll!
Old Jul 9, 2018 | 12:31 PM
f350ktm's Avatar
f350ktm
Originally Posted by senix
Attachment 261287I checked mine, using test strips from accustrip.
Here you go
Very informative summary document, thanks for posting it!
WVSTROKE
6.7L Power Stroke Diesel
15
Jan 25, 2013 12:19 AM
Beachbumcook
Jun 29, 2009 06:12 PM
H1449-6
Mar 24, 2006 05:48 AM
F-250 PSD
Apr 1, 2005 10:48 PM
Savaged1
Oct 9, 2003 06:40 AM
