Looking for some cab help
Old Jul 7, 2018 | 07:28 PM
1low50's Avatar
1low50
When I was younger, I wanted a smooth firewall. So I tore the original out and replaced it. 10 years later I put an original back in and tore the not totally rotted floor out. Everything was done without bracing. 3 more years, I need to fix it right.
Hoping anyone with an original F-1 could give me exact measurements from the cab floor. I need passanger side and drivers side, jamb front to jamb back . Also passanger to driver jamb to jamb front, and jamb to jamb back. Just remember I have NO floor for refrence.
Hopefully thanks in advance.
Chris
Old Jul 8, 2018 | 09:36 AM
CharlieLed's Avatar
CharlieLed
Your doors will give you that dimension. Measure the door, add in the gaps front and rear so that the door is evenly centered, and you have the correct spacing for the jambs.
Old Jul 8, 2018 | 02:32 PM
petemcl's Avatar
petemcl
Those measurements can vary plant to plant. I agree with CharlieLed. Make it so your doors close and open and are gapped perfectly And you will be OK.
Old Jul 8, 2018 | 10:26 PM
52 Merc's Avatar
52 Merc
As I was reading your post, I was thinking exactly what Charlie and Pete said. You can measure 5 different trucks and come up with 7 different measurements. You'll likely get better results if you build your cab to fit your doors. These trucks were never even close to built to the fit and finish of Lexus standards, but doing what you're doing, you certainly can improve greatly on the fit and finish over stock. I look at my cab and can see where they missed on welding the door opening framework together, and the doors will never fit evenly as is.
Old Jul 10, 2018 | 01:37 PM
1low50's Avatar
1low50
That idea was my plans if I couldnt get measurements. I guess the word "exact" may have been a little to tight of a tolerance. I was looking for a good place to start seeing as I have no other reference.
Your words let me know I am at least thinking about it alot better this time around. Thanks
Old Nov 12, 2018 | 08:11 AM
1low50's Avatar
1low50
Just thought I would throw up some pics of my updated progress. I didn't want to fork out the cash for a pre-made floor that would need some tweaking to fit my cab. So I made my own floor.
I made everything as square as I could, and tacked in some bracing. Took some measurements, cut out a wood floor. Cut some shapes in the floor, bolted 2 identical pieces of plywood together with the new sheet metal in the middle.
Slowly used an air hammer with some modified bits. Finally, I had to leave the garage and go to a buddies place that had a sheet metal brake.
If there is any other interest when I get finished, I will update. Thanks everyone
Old Nov 12, 2018 | 08:36 AM
petemcl's Avatar
petemcl
What gauge metal are you using?
Old Nov 12, 2018 | 08:52 AM
tinman52's Avatar
tinman52
Welder User
That looks pretty good! Is there any bracing or support under it? What about the trans tunnel/cover?
Thanks for posting.
Old Nov 12, 2018 | 09:12 AM
CharlieLed's Avatar
CharlieLed
You definitely have skills...I have done hammerforming but you take it to a new level, nice work!
Old Nov 12, 2018 | 10:16 AM
52 Merc's Avatar
52 Merc
Looking good. Pretty impressive, actually. I think I would still want to fit the doors before getting too far ahead with the welding in process. The fit and finish aspect of the build quality of these trucks back then was pretty poor. The cabs were not necessarily square or the same on both sides. You have an opportunity to fix that. Keep us posted.
Old Nov 12, 2018 | 11:43 AM
pweng1's Avatar
pweng1
I have learned from years on this forum always listen to CharlieLED. Before i had a bead roller I used to do those with the cutout and pipe to make the beads. Nice work. I have also made small angle pieces and welded to strengthen flat metal floors.
Old Nov 16, 2018 | 06:39 AM
thepitshop's Avatar
thepitshop
Nice job! Looks really good!
Old Nov 16, 2018 | 07:29 AM
Greg Rogers's Avatar
Greg Rogers
Wow, nice work!
clintonvillian
13
Jan 4, 2018 06:59 AM
toby tough
Jan 20, 2015 08:15 PM
oscajo
18
Jun 17, 2014 07:39 PM
greg1235
Jul 8, 2012 07:42 PM
53pickemuptruck
27
Feb 22, 2009 10:14 AM
