Babe the Blue Ox is SICK!
#31
I wish I could be more help Glenn. I'm only about 300 miles away, but I don't know what I could do anyway. I don't have a 5th wheel setup, just gooseneck. I don't think the law would think much of me pulling your setup with a tow rope that far, and then you are still 300 miles from your place here in SD.
If you think you need to get out of walmart, I'd try and make it through today, then limp it to the nearest campground late tonight when it's dark. I wouldn't go far with it, but it's pretty hurt as it is, I don't think a short trip would hurt much more, just make sure its full of oil before you go.
If there is anything you think I can do to help, please be sure to ask. I'd sell you my truck, but I don't think it's really what you want to do right now.
#32
I definitely need to get out of Walmart parking lot. They haven't said a word to me yet, if they do I'll show them all the oil on my running boards and I'm trying to get it fixed. I have a place in SD 500 miles away and this one company wanted $2500 to tow me there. I could buy a used motor for that, maybe! Of course this happens on a weekend!
I cannot assure you one would let you park the rig, but I can ask if push comes to shove from Wally people.
#33
Glenn, if Walmart starts to ask what your plans are, see if they will let you park in the back. Most have a large area for tractor trailers to turn around for making deliveries. Plenty of room to stow out of the way so you don’t have a personal camp site on their front lot. It will be interesting to see what you find when you pull the injector. Good luck.
#34
I think a crate is about 5k here. Did you check CL?
I did and found this. Do a compression test and this block may be the one.
1995 crew 7.3
1995 crew 7.3
This place popped up on a google map search. That's all I know about them. Their website says they are Nebraska's Powerstroke specialists.
https://hartsdieselperformance.com/
4504 S 28th St, Omaha, NE 68107
402-507-0889
This place has mobile techs who will come to you. Once again, just a google map search is all I know about them. I searched for Omaha Powerstroke.
https://www.hatchermobileservices.com
Shop Location & Information:
Address:7887 F St.
Omaha, NE 68127
Phone:(888) 808-8448
Hours:Mon – Fri: 9am – 6pm
Sat: 8am – 2pm
402-507-0889
Address:7887 F St.
Omaha, NE 68127
Sat: 8am – 2pm
#35
#36
Not trying to be a tool but psd compression I several hundred psi potentially.
#37
I don't think you understood the redneck compression test. You just carefully listen to the motor turning over. All the injectors, glow plugs, etc., are in place so there is nothing spraying or squirting around and not much of a safety hazard. No different than just cranking the motor over, except you are listening carefully. Personally I don't think I have the ears for it unless it's real obvious.
#38
#39
I also don't have the ears also. As it is now I just have a big miss and the miss is the same now as it was before I unplugged the injector. White smoke cleared up after unplugging it alot. Well, twenty minutes and I start calling repair shops. I hope the table or bench they bend me over is nice!
#40
Do you have an injector you can put in it?
I think you are most the way there on finding it but I am couch side which makes a huge difference. If you could pull the injector it may take the guessing out.
Anyhow I wish you the best and wish I was there to help. I am leaving service for the next ten days or so. I may come down out if the mountains to say hi to nick aka MOOSEMACHINE.
#42
#43
