Clicking Flasher after Electronic LED Flasher installed?
My previous thread indicated I changed out front turn signal and side marker bulbs to LED. Had the hyper flash issue so installed a Novia EP 27 Electronic LED Flasher and hyper flashing stopped and blinkers blink normally.
However......now the flasher clicks (as if blinking) when engine is shut down and key is removed.
I can also operate blinkers without key (ignition on).
I tried to operate hazards button several times (read that cleaning contacts this way can help). It did not help.
I can turn key on/off a few times and it will stop clicking. After about 20-30 seconds, clicking will resume.
What can this be?
Thanks!
What can this be?
Thanks!
durst2020
11-01-2011 11:15 AM
bcaughhorn
13
12-13-2010 06:16 AM
