Steering Wheel Swap
Old Jul 4, 2018 | 06:06 PM
Ryno1's Avatar
Ryno1
Steering Wheel Swap
Afternoon all and Happy 4th!
I've searched and found some good write ups on the infamous XLT to Lariat leather steering wheel swaps. Having watched the YouTube videos, I decided to give it a try as I just hate the plastic wheel. The videos made the swap look pretty easy and straightforward but I'll be damned if I'm not having a helluva time getting the airbag to pop out. I was wondering if anyone out there that has done this or at least attempted has any tips or tricks. I have a 2017 F250.
Thanks for the help!
Old Jan 18, 2020 | 11:31 PM
Jimmy Pet's Avatar
Jimmy Pet
Post deleted wrong thread
Old Jan 19, 2020 | 07:52 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I had a helluva time with mine. One of my clips was extra hard to undo. I just kept at it and it finally popped out
Old Jan 20, 2020 | 05:12 AM
dnewton3's Avatar
dnewton3
Yes - they can be a bit difficult to get the airbag to release.
I have some suggestions ...
- First, make sure you disconnect the battery, bleed off the residual power, and wait 1/2 hour before doing any work on the wheel
- Make sure you're using a true rod (metal or wood) that is just about the same diameter as the hole for the release. Using something too small will make the alignment more difficult. (note - I've not had luck with tapered tips; blunt works best for me)
- Gently push the rod in until you feel resistance; put your finger/thumb on the rod to "measure" the distance. Do this on both sides. If you're not coming up with the same approximate distance, then you're not hitting the release mechanism correctly.
- When you push a rod in to release the hook, you must also push in the airbag to help release the retainer hook, then you should feel a slight release; while still holding in on the rod, then pull the airbag out with your fingers at the top/bottom edges on that side
- Repeat the above on the opposite side
- The airbag won't "pop" out of the seat it sits in; you'll have to gently pull it out even after it's released from the locking retainer mechanism
- Once released, be careful to not pull out too far without releasing the electrical connectors
There are a few YT videos that do a decent job of illustration.
Old Jan 20, 2020 | 08:39 AM
Mkos1980's Avatar
Mkos1980
I had a tough time too until I used a T handle allen. Then it popped out easy.
Old Jan 20, 2020 | 11:45 PM
Jimmy Pet's Avatar
Jimmy Pet
+1, this was the winner for me. T Handle 3mm allen did the trick for me.
Old Jan 21, 2020 | 02:40 AM
ZAR2USA's Avatar
ZAR2USA
Thanks for excellent write-up.
Old Oct 24, 2023 | 05:02 PM
Je942010's Avatar
Je942010
Wrong thread
AlumadutyAZ
Jun 2, 2026 04:39 AM
Vertigo RT
2004 - 2008 F150
Jun 4, 2018 12:31 PM
eyoung14
Jan 17, 2018 08:34 PM
KennyG228
Dec 29, 2014 09:52 PM
LibertyOrDeath
Aug 31, 2003 05:11 PM
