Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
N950 Resurrection
Old Jul 1, 2018 | 04:49 PM
Tim Spencer Jr's Avatar
Tim Spencer Jr
N950 Resurrection
I have every Ford Truck Parts Catalog from 1928 thru 2001, so I can decode all the VIN info, codes from the Rating/Warranty Plates and the Certification Label first used in 1981.
If you need parts, obsolete or not, I can look up the numbers, then search for them on two online websites to see if anyone has them. Then will post the part numbers, sources that have them.
If the parts are still available, I will list the MSRP and the FTE member discount price offered by sponsor PARTSGUYED.COM (Ed Olson, parts manager of Horizon Ford in Seattle WA).
I've been doing this jazz on FTE since 11/04/2006. And, btw: One of the parts locator sites is only accessible to FoMoCo Dealers.
Finally got the door open and found it any info would be greatly appriciated.
the front left leaf spring is missing the greaseable pin that connects to the frame.
Old Jul 1, 2018 | 06:53 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Tim Spencer Jr
Finally got the door open and found the Warranty Plate. The front left leaf spring is missing the greaseable pin that connects to the frame.
N95 = N950 (gas).
K = 477 4V
U = Louisville KY Assembly Plant.
F90190 = 1969.
146" Wheelbase.
COLOR code: Blank.*
N955 = N950 (gas), 32000 lbs. GVWR
4081: 40 = Black all Vinyl / 81 = 81A Standard Cab.
N = Dana (Spicer) model 6352 5 Speed Direct.
DPE:
DP = Eaton model 19221 Two Speed Rear Axle / 6.17/8.40 / 23,000 lbs. Rear Axle Capacity.
E = Ford-Rockwell/Timken 9,000 lbs. Capacity Front Axle without H/D brakes.
32,000 lbs. Gross Vehicle Weight Rating.
222 net HP @ 3,200 RPM
210629:
21 = Atlanta GA Ford District Sales Office, where the original selling dealer ordered the truck from.
0629 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order.
Pic: Which part is missing?
Old Jul 1, 2018 | 07:27 PM
Tim Spencer Jr
N950 resurection. Looking for a vin devoder.
[QUOTE=NumberDummy;18065849]N95 = N950 (gas).
K = 477 4V
F90190 = 1969.
146" Wheelbase.
COLOR code: Blank.*
DPE:
210629:
5780 and the grease pin.
Old Jul 1, 2018 | 07:37 PM
NumberDummy
N95 = N950 (gas).
K = 477 4V
F90190 = 1969.
146" Wheelbase.
COLOR code: Blank.*
DPE:
210629:
Grease pin, do you mean 87901-S that is the Zerk (grease) fitting? If so, see below...
C1TZ-5780-F .. Front Spring Shackle Stud / Obsolete
GREEN SALES CO. in Cincinnati OH has 31 = 800-543-4959.
87901-S8 .. Zerk Fitting ~ 1/8" -28 / Obsolete
GREEN SALES CO. has 111.
Note the 8 = parts catalog pic doesn't show the complete suffix.
Old Jul 1, 2018 | 08:47 PM
Tim Spencer Jr
[QUOTE=Tim Spencer Jr;18065889]
N95 = N950 (gas).
K = 477 4V
F90190 = 1969.
146" Wheelbase.
COLOR code: Blank.*
DPE:
210629:
front engine cover parts and cab corner parts.
Old Jul 2, 2018 | 11:11 AM
NumberDummy
[QUOTE=Tim Spencer Jr;18066016]
Old Jul 3, 2018 | 04:10 PM
Tim Spencer Jr
N950
Looking for parts list and breakdowns of the front and rear axle.
Old Jul 3, 2018 | 04:20 PM
85e150's Avatar
85e150
Big truck with a big list of questions gets it's own thread. Good luck with it!
Old Jul 4, 2018 | 11:04 AM
NumberDummy
Pics of 9,000 lb. front axle (upper) and two speed rear axle (lower) from the 1964/72 Ford Truck Parts Catalog, available on a C/D from hipoparts.com
Old Jul 7, 2018 | 12:40 PM
Tim Spencer Jr
Hood parts available.
Some ruff beginnings.
Do u possibly have a good hood parts breakdown for truck.
Old Jul 7, 2018 | 09:24 PM
NumberDummy
Old Jul 12, 2018 | 07:39 PM
Tim Spencer Jr
Numberdummy
Hey do possibly have a break down of the front wheel hubs.
shillinghillf600
Large Truck
Mar 30, 2019 12:16 AM
6557iam
Large Truck
Mar 16, 2019 04:35 PM
Elijah Ford
Large Truck
Apr 7, 2018 08:36 PM
19hoosierdaddies87
Large Truck
Apr 4, 2018 07:02 PM
robengel
Sep 9, 2015 08:25 PM
