Gas Guage
Old Jun 30, 2018 | 03:16 PM
Light Doug's Avatar
Light Doug
Gas Guage
My gas gauge only goes to 1/2 tank and is not accurate at all to empty. What to change?
Thank You.
Old Jun 30, 2018 | 05:39 PM
john jamieson's Avatar
john jamieson
The first thing I would check is to pull it and see what shape the float is in. See if has developed any leaks and is partly filled.
Old Jun 30, 2018 | 09:09 PM
AZ66F100's Avatar
AZ66F100
Yeah, what John said. Pull the sender/float assembly out of the tank and check the float. Also turn the key on and move the float arm all the way from empty to full (and various points in between) and see what the gauge reads.
Old Jun 30, 2018 | 09:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The float is made from two pieces of brass soldered together. Solder breaks down, gas seeps in, float settles towards the bottom of the tank.
Float is available from Ford and is the same 1957/79 Passenger Cars/trucks, 1961/79 Econoline and 1966/79 Bronco.
hivoltj
16
Dec 13, 2016 07:57 AM
JD_F100
26
Aug 31, 2014 10:26 AM
Htarpley80
2004 - 2008 F150
13
Mar 26, 2014 08:28 PM
davidmoss1992
18
Jan 30, 2012 12:03 AM
jejdavis
Mar 25, 2011 05:11 AM
