Cetane Booster PM22A?
Old Oct 6, 2019 | 09:42 AM
schrod's Avatar
schrod
Originally Posted by tony m 6.7
But keep in mind, even though it was designed to run on 40 cetane, the higher the cetane the cleaner the burn. Which is critical for the emissions systems in these modern diesels.Less soot means less regens. Lubricity and the other benefits from a fuel additive are also added insurance against fuel system wear and damage. Our commercial fuel supplier has stated numerous times that "fracking" for oil does tend to draw more moisture out of the ground than normal drilling methods.
That may well be true. However, after refining the only moisture in the fuel would be after the fact contamination. If you understand how fuel is refined you would realize how ignorant this fuel supplier is.
Old Oct 6, 2019 | 09:46 AM
schrod's Avatar
schrod
Originally Posted by Thamac15
I used the Motorcraft cetane booster a couple times, but been using OptiLube Summer Plus and their Winter formulas since May 2017 at 1k miles. So far 37k miles on the truck and it still runs great. Change my oil every 5k, engine air filter and both fuel filters every 15k. Only fill up at a high use Chevron.
I have been using OptiLube cetane booster for at least 6 years now. Great product and have never ever found water in the filter drain. Used OptiLube on my 2014, my 2016, and now my 2019. I think it is really the best product out there. I buy 2 or 3 gallons at a time from their website. Always delivered by Fed-Ex.
By the way, ALL diesel fuel you buy today no matter who you buy it from contains at least 5% Bio. Federal mandates to get rid of sulfur which was the lubricity for the pumps and injectors resulted in adding Bio-diesel as the cheapest best lubricator. There is nothing wrong with bio-diesel diesel fuel.
Old Oct 6, 2019 | 09:48 AM
Thamac15's Avatar
Thamac15
Which Opti-Lube product(s) have you been using? Ever done the Single Clean one?
Old Oct 6, 2019 | 11:22 AM
schrod's Avatar
schrod
I have only always used the Opti-Lube XPD for summer and dbl the dose for winter. I have no knowledge of this Single Clean.
Old Oct 6, 2019 | 11:41 AM
Busa 1 Dave's Avatar
Busa 1 Dave
This is a common misconception that has gone on from one thread to another for years when in fact it is not really true. The SULFUR REMOVAL PROCESS is the real problem.
https://fueloilnews.com/2010/03/04/t...-of-lubricity/
https://www.sciencedirect.com/scienc...76610215013879
Old Oct 6, 2019 | 02:37 PM
schrod's Avatar
schrod
You may think it is a misconception but the truth is the sulfur had to be removed per EPA to stop acid rain. The sulfur was actually the lubricity agent. If it wasn't then they would have just re-introduced the lubricity that was removed with the sulfur.
Old Oct 6, 2019 | 04:08 PM
1olddogtwo's Avatar
1olddogtwo
Wait .......
It doesn't come straight from the ground?
Going on a 150K (2017) and have never used anything except some anti-gel during the polar vortex this year.
On my 6th personal 6.7 (2018) and have never used any except power service during extreme cold. I believe the rest is primarily snake oil or is not needed.
Rob_17
May 11, 2017 09:53 PM
KC8QVO
6.7L Power Stroke Diesel
63
Jan 27, 2017 03:41 PM
my_crib_too
Jan 10, 2015 02:20 AM
SDIceman
6.4L Power Stroke Diesel
Dec 30, 2012 10:05 PM
Gearitis
Jan 13, 2010 03:18 PM
