t18 trans swap
Old Jun 29, 2018 | 10:55 PM
Glxy66's Avatar
Glxy66
t18 trans swap
I am wondering if a 1970 NP435 will bolt into my 1970 F350 that has a t18? My t18 has a pto and I'm also wondering if it will fit and work with the NP435. What will be the modifications needed, if any. for this swap. Both transmissions are 1970's out of F350"s, both 2WD, and both have 360 engines. Will there be any driveshaft issues? I appreciate any info/help, Thanks.
Old Jun 29, 2018 | 11:18 PM
85e150's Avatar
85e150
PTO is the same side.
It should bolt up to the bell and use the same clutch. The transmission to bell is the same. Input length, spline, input tip and bearing retainer are the same.
Overall length differs by 1".
The 1" MAY be an issue; you will have to measure and see if you have any adjustment in your mountings.
Is your T18 worn out?
Source:
https://www.novak-adapt.com/knowledg.../manual/np435/
Last edited by 85e150; Jun 30, 2018 at 12:02 AM. Reason: Rearrange, add link, confirm some info
Old Jul 1, 2018 | 10:43 AM
Glxy66's Avatar
Glxy66
Thanks for the response. My t18 has some bearing groan in 3rd gear and the shifter is like a golf club stirring in a 55 gallon drum! I believe these two problems can be repaired but I thought if if I could just yank one trans out and pop another one in ..............
Glxy66
Jul 25, 2018 12:46 PM
joefords
Nov 16, 2003 06:24 PM
Njbmx
Feb 3, 2003 01:07 AM
moore1960
Oct 31, 2002 08:12 AM
moore1960
Oct 26, 2002 10:32 AM
