Courtesy Light replacement 92-96?
Old Sep 21, 2003 | 04:42 PM
c_rossman's Avatar
c_rossman
Has anyone ever replaced the light bulbs on your doors, I cant seem to get them out of the socket, I accidently pushed the socket into the door and will have to fish it out on the passanger side. Also where do you buy a dome light bulb for 92-96 pickups?
Old Sep 21, 2003 | 06:37 PM
NoMo's Avatar
NoMo
The bulbs just pull straight out on my '97.
My local Autozone has a good selection of replacement bulbs.
Old Sep 21, 2003 | 07:00 PM
c_rossman's Avatar
c_rossman
Ok, I will go give it a shot, I have looked at Napa, They told me I could only get the dome light at a dealer. Thanks
Old Sep 22, 2003 | 10:40 AM
NoMo's Avatar
NoMo
The 'dome' light is one of the few bulbs that I have not replaced in the F250.
I have purchased the door courtesy lights, tag lights, and cargo/third brake lights at Autozone within the past month. Best way to do it is to read the number on the old bulb (if you can). If you can't read the number and the parts store can't help, ask here on the forums. If the numbers from my '97 don't match up, maybe someone else with the same model truck as your will answer.
Old Sep 22, 2003 | 11:23 AM
c_rossman's Avatar
c_rossman
I found the dome light at Mills fleet farm, It is a sylvania 912, pretty common, but Napa didnt have it in the book.
Old Sep 22, 2003 | 11:32 AM
c_rossman's Avatar
c_rossman
Yes, And the door lights pulled right out, Just took a bit of wiggling.
Old Sep 22, 2003 | 06:42 PM
Pastmaster's Avatar
Pastmaster
My '93's owner's manual states what each bulb is. Have you looked at yours?
Old Sep 22, 2003 | 10:49 PM
c_rossman's Avatar
c_rossman
I have got it all figured out. Thanks everyone. 912's for the Dome light and the smaller version of the 912's for the door lights, forgot the # allready! Also 912 for the light behind the cab facing the box.
