Oil sending unit ????
Before I tore into my truck one thing that did work was the oil pressure gauge. Now that I have my rebuilt engine in and rewired I cannot get the gauge to work. I'm looking for possible issues. Here is a little more information:55' 239 Y that is 6 volt negative ground. Truck was negative ground when it worked before and I left it negative ground. I followed the wiring diagram to a "T". Do you think I have to flip flop the wires on the gauge? I'm confused though because the temperature gauge is working and I wired it according to the diagram and they share a common wire. Any advise from you professionals would be awesome.
Also, why does the sending unit have two prongs on it? I only remember there ever being one wire attached to it.
The two spades on the sending unit are common to each other, take your pick. Are you using Teflon tape on the threads, I think I see a hint of it. Don't use it, it's an insulator.
Pos / neg ground doesn't matter. Check for power at the gauge, may just be a bad connection.
Thank you. Let's hope that works!
Bob (Mixer man) bailed me out on this and it is greatly appreciated. Also, thanks Ross for your words of wisdom. I have an oil pressure readingEdit- I tried to add your reputations but it would not allow me too. It said I need to spread it around. That's BS
