Sponsored by: Auxito
HELP! can't get into program mode
Old Sep 21, 2003 | 02:23 PM
vicdanj's Avatar
vicdanj
Unhappy HELP! can't get into program mode
I need help (f150 2000 4x4 5.4) .... I am trying to program a keyless entry remote and the truck will not go into program mode. Method used> insert key and turn from position 3 to 4 eight times within 10 sec... at this point the truck should lock and unlock the doors to signify that it is in prog mode. IT DOES NOT! I have been trying for a couple of hours and no luck. I need some help here.
Old Sep 21, 2003 | 04:09 PM
aldridgec's Avatar
aldridgec
are you sure you have keyless entry on that truck?
Old Oct 11, 2003 | 07:39 PM
thepartsgod's Avatar
thepartsgod
same problem
I have the same problem with my 99 f150. The owners manual says it has keyless entry, but states you have to go to your dealer to have them programmed.
Old Oct 11, 2003 | 08:46 PM
LxMan1's Avatar
LxMan1
Normally, if it doesn't work by doing the key thing, it isn't equiped with keyless entry.
Jimmy
Old Oct 12, 2003 | 11:03 AM
aldridgec's Avatar
aldridgec
The owners manual talking about keyless entry doesn't mean that it has keyless. Not all were equipped.
Old Oct 12, 2003 | 11:05 AM
aldridgec's Avatar
aldridgec
One way to do a physcial check is to look under the drivers side dash for a white box on the firewall to the left of the brake pedal. If it says Remote Access on it and has a 5 digit number in large bold lettering it probably has keyless.
