This is why you need a pre filter/seperator. **video and pic**
Old 06-27-2018, 10:59 AM
JT250's Avatar
JT250
JT250 is offline
I installed the Racor PS120-02 several years ago. Here is my original post. Racor PS120 I have not emptied it since that day. I had a fuel pump issue this weekend and noticed the Racor had a lot of gunk settled in the bottom. This is the very reason I decided on this filter. The housing is clear so you can inspect it whenever you need to. If you go with the Badlwin type filter you never know if/when you need to change it. Also the Baldwin is not re-usable so you are spending money every time you decide to change it. I am very happy with the Racor PS120. Here is a link to the video. I am not able to download it yet as google says it is still processing. I hope this works. If not I will upload it when it is ready. Contaminates filtered out of fuel
Old 06-27-2018, 11:08 AM
brandon_oma#692's Avatar
brandon_oma#692
brandon_oma#692 is offline
Ok I am sold. THANKS YOU Now to add this to the to do list later this year.
Old 06-27-2018, 11:46 AM
Idaho_F250's Avatar
Idaho_F250
Idaho_F250 is offline
I was already sold, but after seeing this a Racor had been bumped up on the priorities!
Old 06-27-2018, 11:59 AM
F250_'s Avatar
F250_
F250_ is offline
I used the Baldwin on my truck and small inline glass bodied strainer on my Excursion. After picking up some trashy fuel in the Excursion and plugging that little inline glass unit several times, I found out about the PS120 and put one on each vehicle! If I had been aware of the PS120 to start with neither the Baldwin nor the glass bodied strainer would have ever been installed to begin with.
Old 06-27-2018, 04:14 PM
Sous's Avatar
Sous
Sous is offline
Received 4,464 Likes on 2,853 Posts
Each time I change the oil on the truck I closely inspect the Racor container with a bright light to see if there is anything settled in the bottom. The only time I had to clean it out (so far) is right after doing the H/H mod and had some debris left in the tank.
I also fully support the Racor.
darren32
6.7L Power Stroke Diesel
101
05-26-2012 07:44 AM
JonArmy
02-24-2012 03:12 PM
kper05
02-05-2012 07:29 PM
PstrokeN
02-03-2012 12:16 AM
MSF350
04-23-2009 08:56 PM
Quick Reply: This is why you need a pre filter/seperator. **video and pic**
