E4OD died,,,,can I use a torqshift
Old Jun 26, 2018 | 06:57 PM
Willyowill's Avatar
Willyowill
Is that the name of the newer tough as nails Ford transmission I've got a 95 RV with a fuel injected 460 so I wanted something that would bolt up but I don't know about all the computers and whether they have to talk to each other or just the throttle positioning switch
Old Jun 26, 2018 | 08:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It won't bolt up. EVERYTHING is different. The computer that runs a 460 won't shift a TorqShift, and a computer that shifts a TorqShift won't run a 460. You'll need to invent a computer that can work, and build a wiring harness. It would be a lot cheaper to scrap your RV and buy a brand new one than to try and put a TorqShift in your RV.
Old Jun 26, 2018 | 11:35 PM
HT32BSX115's Avatar
HT32BSX115
Yeah, you might be able to when US Shift gets their "Shift" together to support the 5R110. (but right now, they don't)
Quick 6 Stand-Alone Transmission Control They also sell complete wiring harnesses.
But then you would probably have to change the engine to something that would bolt up to the 5R110........like a V-10, 6.0 or 6.4 diesel etc....How much money do you have to spend?
I am thinking I agree.......A LOT LOT cheaper
The E4OD I have came out of a 94 F450 with a service bed that routinely hauled a big trailer with a mini-excavator on it. (about 22,000lbs GCVW)
He ran it 180,000 miles before he had it rebuilt the first time! After that he pulled it to install a ZFS-5 5-speed trans. Only thing wrong was the front seal leak. Other than that it was fine.....I suppose you could put a ZF in your Moho, but then you'd be "pushing gears"!!
You're much better off just getting your E4OD rebuilt. An E4OD properly built is a good transmission.
Regards,
Rick
jseim44
Feb 13, 2014 09:16 AM
phatfantom68
Feb 21, 2008 02:34 PM
zukota
Aug 8, 2005 08:53 AM
Sand Bronco
1978 - 1996 Big Bronco
Feb 3, 2004 10:57 AM
jkiser96
Mar 22, 2002 07:38 PM
