Steering Coupler/Rag Joint
Old Jun 26, 2018 | 05:36 PM
James_Western_Canada's Avatar
I had a call from a friend waaaay down in the south part of the province earlier today, he discovered that his Rag Joint was literally hanging by threads, and wanted to know about compatibility, etc.
Early this afternoon, when I got back to my across town & back roadtrip, I went to the shed to see if the rag joint was still on the column we saved out of a '66 Custom Cab we eviscerated a year or more back, of course, it wasn't there
So I texted John to let him know.......and a short while ago, I got a text back.......
"Just finished. Got universal Borgeson Rag Joint, and it worked fine. Ground the heads off two bolts & pounded them out of the spline end of the joint & bolted the new Borgeson Rag in. The Borgeson Part No. is 000941. Called Replacement Rubber Rag Joint Kit. Fit like it belonged."
So, there you go, an economical solution that should be made from quality materials, unlike some of the off-shore repops
Borgeson Rubber Rag Joint Disc
Replacement rubber rag joint disc with hardware. Fits many Chevy , Dodge, Ford and Jeep applications requiring a 3.25" diameter rag joint disc.
James
Last edited by James_Western_Canada; Jun 26, 2018 at 07:25 PM. Reason: Fixed url for rag joint
Old Jun 27, 2018 | 09:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Both 'rag joints' used on 1965/66 F100/250 2WD are available NOS:
C5TZ-3A525-A .. Steering Coupler (aka rag joint) - Larger pin is .41" O.D. / Obsolete ~ 374 available NOS
1965 F100/250 2WD; 1966 F100/250 2WD before serial number 900,001.
C6TZ-3A525-A .. Steering Coupler (aka rag joint) - Larger pin is .56" O.D. / Obsolete ~ 24 available NOS
1966 F100/250 2WD from serial number 900,001; 1967/68 F100/250 2WD
Old Jun 27, 2018 | 09:54 AM
Well, first off, the info would be more helpful to future readers of this thread if the sources were listed.....but in the end, it's moot, as the truck is Johns DAILY DRIVER, so he didn't have the luxury of ordering a part from somewhere in the US and waiting for it to show up,
But even in a city in southern Alberta, he was able to source the Borgeson piece locally and be back on the road the same day the issue was discovered........
James
Old Jun 27, 2018 | 10:25 AM
NumberDummy
Originally Posted by James_Western_Canada
Well, first off, the info would be more helpful to future readers of this thread if the sources were listed......
I've listed both part numbers and their sources multiple times in the past, so I'm not going to list the sources again unless asked, because it's a lot of work.
I just typed C5TZ-3A525-A into the search box, 25 threads came up.
Old Jun 27, 2018 | 10:42 AM
From a post on 12-02-2017, 01:25 PM
TWO different steering couplers for 1966. It depends on the size of the large pin and what the last 6 digits of the VIN is.
C5TZ-3A525-A .. Steering Coupler - Larger pin is .41" O.D. / Obsolete ~ Available NOS
GREEN SALES CO. in Cincinnati OH has 38 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 385 = 800-476-9653.
C6TZ-3A525-A .. Steering Coupler - Larger pin is .56" O.D. / Obsolete ~ Available NOS
1966 F100/250 2WD from serial number 900,001; 1967/68 F100/250 2WD & F350.
GREEN SALES CO. in Cincinnati OH has 19 = 800-543-4959.
Mercmeister
Sep 2, 2025 11:50 PM
pchelp
Sep 9, 2017 08:47 PM
MIKES 68 F100
29
Apr 12, 2017 04:45 PM
oldshep66
Feb 27, 2013 12:08 PM
Schuyles
Jul 11, 2012 12:26 AM
