Highway downshifts
Old 06-26-2018, 08:51 AM
Workingstiff's Avatar
Workingstiff
Workingstiff is offline
Highway downshifts
94 f150 302 4R70W
Hi folks, on 4 different occasions, my truck has downshifted on the eway for no reason. I let off the gas it upshifts immediately and all is fine. No flashing lights other than airbag. All fluids changed 5k miles ago. PSOM taken from my 5 speed. Alls been good for months.
Old 06-26-2018, 09:11 AM
Conanski's Avatar
Conanski
Conanski is offline
Received 1,022 Likes on 802 Posts
Originally Posted by Workingstiff
94 f150 302 4R70W
Hi folks, on 4 different occasions, my truck has downshifted on the eway for no reason..
So you were cruising along on level ground at moderate speed(ie light throttle input) and the trans downshifted? Regardless you need to pull codes and post up what you find.
Old 06-26-2018, 09:48 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Da_Lariat_Chariot is offline
Conan is right, the computer will store a code if some error occurs and not turn on the check engine light, I have actually never seen mine illuminate while running in the 5 years I've owned it. It always stores the code (if one occurs) in continuous memory.
Old 06-27-2018, 04:44 AM
Workingstiff
Yep. Downshift, it was light throttle, about half a toe's worth,lol. We're not talking unlocking the torque converter- its downshifting to about 3500 rpm on the highway.
. Pulling codes is always a good thing. But, it was my understanding that the engine and trans are 2 separate systems.
Old 06-27-2018, 06:28 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,193 Likes on 942 Posts
Pullin codes is always a good thing. But, it was my understanding that the engine and trans are 2 separate systems.
You are mistaken.
The same computer controls the engine and transmission. That is why it is called the Powertrain Control Module.
jergar4
09-19-2018 05:19 PM
f100today
06-20-2018 08:59 AM
inferi
09-29-2010 07:50 AM
JOHN CHAPPELL
05-15-2008 01:55 PM
csbingham
1997-2006 Expedition & Navigator
12-27-2004 04:50 PM
Quick Reply: Highway downshifts
