Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1966 N600
Old Jun 25, 2018 | 10:56 AM
Phillip Fleming's Avatar
Phillip Fleming
1966 N600
Hello, I just picked up a 1966 N600. I am having trouble finding parts like weatherstripping, instrument panel, gauges, glass and other interior parts as well as lighting. Any suggestions? Thanks.
Old Jun 25, 2018 | 05:42 PM
85e150's Avatar
85e150
Welcome to FTE.
Much of your cab is shared with the smaller trucks. Check post 39 here:
https://www.ford-trucks.com/forums/1...68-n600-3.html
But maybe before that, inspect your wheels. From this distance, I see evidence they are the deadly "widowmaker" type wheels. Unsafe at any speed.
Ford two piece rims
Lots of pictures here and on the web if you search "widowmakers".
Old Jun 25, 2018 | 08:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
ALL the weatherstripping (windshield, back glass, door/window) is the same: 1961/66 F100/1100; 1963/69 N/NT500/1100; 1967/69 F800/1000 because all these trucks use a similar cab.
The only real difference is the N/NT doors are cut out at the front for fender clearance. All the glass is the same, as is the doors internal parts for these trucks.
The problem is, that the repro parts sellers only list the weatherstrips and etc parts for 1961/66 F100/350.
Round speedo instrument cluster parts are also the same. Some of the switches on the dash are the same as is the dome lamp, but only for specific years. Anything else you'd like to know?
Pic: Door internal parts including weather strips:
Old Jun 25, 2018 | 09:48 PM
Phillip Fleming
Thank you for the info. That was my next question about the wheels. I would like to put 22.5’s on it with super singles on the back. Is there such an option??
Old Jun 25, 2018 | 11:50 PM
85e150's Avatar
85e150
6 lug 22.5s for super singles..... Hard to find.
One option:
Obsolete - American Wheel Specialist
This pops up:
https://www.ford-trucks.com/forums/1...ll-6-lugs.html
There are a lot more, and a couple members here have dealt with this.
One other solution is 20" tube-type wheels with locking rings. These are safe and serviceable and more available than the 6 lug 22.5s.
Follow the links in post 2:
https://www.ford-trucks.com/forums/1...1967-f600.html
Old Jun 27, 2018 | 10:43 PM
Phillip Fleming
Vin de-code
Old Jun 27, 2018 | 10:44 PM
Phillip Fleming
VinDecode
[QUOTE=Phillip Fleming;18059805]
[/could I get some info on the vin?QUOTE]
Old Jun 28, 2018 | 11:46 AM
NumberDummy
N60 = N600 (gas).
C = 330 2V Medium Duty FT engine.
U = Louisville KY Assembly Plant.
868113 = 1966.
144" Wheelbase.
J = Rangoon Red.
N600 (gas) .. 17,000 lbs. GVWR
E81: E = Red Crush Vinyl & Red Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
F7B:
F7 = Eaton model 13802 Two Speed Rear Axle / 5.83/8.11 / 15,000 lbs. Rear Axle Capacity.
B = Ford 5,500 lbs. Capacity Front Axle.
17,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3800 RPM
530569:
53 = Kansas City MO Ford District Sales Office, where the original selling dealer ordered the truck from.
0569 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Jun 28, 2018 | 06:17 PM
unilover6163's Avatar
unilover6163
Welcome to the FTE Phillip.
Love your truck.
Can you post some close up photos of your cab, interior, engine compartment, under floor area, what ever you can provide of your N600?
Love seeing those survivor trucks still living their lives.
Best of luck with your preservation efforts.
Where are you located?
firstrider
27
Jan 27, 2021 01:10 PM
emeraldcoupe
Nov 30, 2016 08:51 AM
54TexasF100
Oct 8, 2015 12:09 AM
fordCOE
15
Nov 1, 2011 10:02 PM
joey c
Sep 8, 2008 04:18 AM
