OEM quad beams
Old Jun 24, 2018 | 10:08 PM
3sconnor's Avatar
3sconnor
OEM quad beams
Hello all, I did a halogen to Led conversion on my head lights about a year ago using an aftermarket headlight conversion. Last week I added OEM led tail lights. I made some chants using Forscan and everything seemed to be working great exception change the setting for oem led headlights. Doing that makesmy interior lights go dimband bright non stop even with the door closed. Is there away to convert to an OEM harness when doing this conversion like the taillights ?
Old Jun 25, 2018 | 06:28 AM
Redrockerstl55's Avatar
Redrockerstl55
Are you just replacing the bulbs when you go led?
Tail lights need resistors so you don’t get hyper flash. Other than that if you are just replacing halogen bulbs for led it’s plug and play. No FORScan.
Old Jun 25, 2018 | 10:31 AM
3sconnor's Avatar
3sconnor
I changed the entire housing to the quad beam housing. The taillights have also been done. I was able to get the rear harness with the correct plugs and change 2 wires around. I then used Forscan to change the settings to rear LED and they are working great, no hyper flash. But now I want to do the same with front. It works fine now but I want it to be more factory
Myf350sd
Aug 19, 2019 06:14 PM
GORDEN1234
2015 - 2020 F150
Mar 6, 2017 08:13 PM
rangerbait
6.7L Power Stroke Diesel
Feb 13, 2016 06:03 PM
xmontex4
Feb 21, 2011 07:40 PM
04f15083
2004 - 2008 F150
Oct 2, 2005 12:07 PM
