How much lift is the Snow Plow/Camper on the front?
Not to hijack, but this is along the same lines...
looking at an f250 with the high capacity trailer, no camper or snow plow. I asked them to look up the front spring code from the vin and 5c345310add is what they came up with. The truck is at another dealer so can’t easily look at sticker in door. Is that the 5600# springs?
Are you FX4?
I'd have to look at my build sheet to see but I recall that you only got the upgraded fronts if you didn't already have them from another option. Not sure. I'd have to look but my recollection is that the snowplow/camper gives you 2 up springs (same as on the heavy service front suspension package) while camper only gives you 1. I have a 250 but I think this is the same for 350.
My truck is 2.5" lower in the front than rear. But once the 2,400 loaded camper is put on I am guessing it will level out. What I am most interested in is buying new shocks for off-road performance. Every shock brand wants to know how much the truck is lifted over stock configuration. I can't find an answer how much the SP/C option changed from stock.
