2011 F350 dually poor fuel economy
I have a 2011 f350 6.7 dually with 190k, bought it with 180k. Truck is tuned and deleted. Since I bought it, it only gets 11-12.5mpg empty with the cruise set at 75-80. Buddy has the same truck (2011) in a srw, also tuned and deleted, and pulls around 18 at the same speed. Any ideas on what could be causing this? No check engine codes.
Previous owner could have done some modifications (injectors, etc) in an effort to generate more horsepower... Was the PO towing ? Did it come with a gooseneck hitch setup in the bed? You may have a truck that get's 11-12.5 mpg regardless of being empty or pulling a heavy load....
Hobo
When you bought the truck, did it come with the tuner? If not, do you know if the previous owner still has the tuner? The installed tune might not be ideal for fuel mileage. Without the tuner, you might SOL on doing much about the mileage.
Also, lift up on the right foot some. Your best mph whether deleted or stock is around 65 mph.
Your comparing a dually to a SRW. Could be a difference in gear ratios, could be different tunes. There is extra rolling resistance of 6 tires on the ground vs 4 not to mention wind resistance of the dually fenders. I would imagine the dually weighs more as well. To many apples to oranges for a proper comparison in fuel mileage.
I get roughly 2 mpg less than other users here with the same truck, only difference is I have Toyo AT tires and they are running stock Michelins.
Anthonyjbartley
10-12-2014 03:08 PM
