Error Codes
Old Jun 24, 2018 | 06:07 AM
swmpbgy1's Avatar
swmpbgy1
Error Codes
Good morning all......
I just got got back from a 500 mile trip and the Ex bucked several times. The CPS was replaced with a Ford purple/blue “C” model CPS earlier in the week because of similar problems weeks before.
Pulled the codes odes this morning:
DTC #01 - P0344
DTC #02 - P0603
DTC #03 - P1670
I purchased a spare CPS.....should I change them out? What causes the 1670?
Thanks......
Swmpbgy10
Old Jun 24, 2018 | 06:50 AM
EXSwap's Avatar
EXSwap
More engine specifics would help. 7.3? Swapping out the CPS might not be a bad idea, but I’d be checking wiring for chafing before I started replacing parts. Sounds like to me you’ve got some communication errors going on and I’d be looking at wiring first. I wouldn’t imagine your PCM or IDM just happened to crap out on you. I believe the 1670 leans towards a bad IDM or at least a bad connection between the two.
Old Jun 24, 2018 | 06:54 AM
swmpbgy1's Avatar
swmpbgy1
Yes.....7.3l.....I just replaced the CPS 2 weeks ago with the Ford purple/blue “C” model....purchased a spare....should I go ahead and put in the new spare CPS?
Swmpbgy1
Old Jun 24, 2018 | 06:56 AM
swmpbgy1's Avatar
swmpbgy1
Where is the pcm and idm located....a pic would be helpful.
Swmpbgy1
Old Jun 24, 2018 | 07:10 AM
EXSwap's Avatar
EXSwap
PCM I believe is up under the dash next to the parking brake. IDM is under the drivers front fender. As in, you gotta take off the fender to get to it. I haven’t looked at the tech folder (excursion and 7.3 forum), but I’d have to believe someone around here has changed one at some point.
As as far as replacing the CPS, if you just replaced it, I don’t see a reason to replace it again just for the sake of replacing it.
Old Jun 24, 2018 | 07:26 AM
swmpbgy1's Avatar
swmpbgy1
But I get the P0344 code.....indicating the CPS is bad or malfunctioning.....correct?
Old Jun 24, 2018 | 08:36 AM
EXSwap's Avatar
EXSwap
Well, yes, but if it were me I’d check all the wiring first being that it was just replaced. Could very well be a bad sensor, but given your other problems, wiring would be my first check IMHO.
J76251
Sep 28, 2017 03:50 PM
Thewiller
19
Nov 19, 2010 02:27 PM
jsq
Sep 17, 2006 08:24 PM
perrybmw
Mar 17, 2006 08:07 PM
Cowboy350
May 18, 2005 09:00 PM
