Hello
I have a 72 F250 4WD standard trans pickup. Base model, standard cab & 8' bed. I just installed a NP205 transfer case from a 75 highboy and need a different speedometer cable. The one I removed measured approximately 107" end to end. I am not having any luck finding one on line. Anyone run into this? Any suggestions, advice would be greatly appreciated.
Thanks
Joh
You cannot use a 1973 and later cable, because it attaches to the speedometer head differently.
No one has any of the original C7TZ-17260-AA 1967/72 F250 4WD cables (101.42" long) NOS
If you type C7TZ-17260-AA into the search box, you'll find several related threads.
