55' door hinges. Right, Left, or does it make a difference?
So when I took my door and hinges off I did not mark them driver , passenger, upper, or lower. I am now getting ready to put them back on. I thought I read somewhere that they are side specific. Is that true or are they the same? They look the same to me. Also, on a different subject, what size amperage fuse is on the headlight control switch? Thanks for the help. Dave
I don't think there is a difference. Some would say have the head of the pin on top. But I don't think the pins will fall out, do you? Upper and lower are the same.
I think the fuse at the end of the headlight switch is for the dome light and you do not have one do you? Unless you go to the Dark Side like I did and put one in!
BTW, I have an NOS dome light if you or anyone else is I interested...,
