1978 - 1996 Big Bronco
Back window leaks??
Old Sep 19, 2009 | 08:28 PM
oatsj's Avatar
oatsj
Question Back window leaks??
96 Bronco back window leaks .The gaskets and seals all look good can't figure out how it is coming in any suggestions??
Old Sep 19, 2009 | 11:10 PM
g_k50's Avatar
g_k50
I would suggest tracing the wet part with a flashlight and removing interior panels and carpet until the wet part becomes a "hole" part. Then plug hole.
Old Sep 19, 2009 | 11:59 PM
greystreak92's Avatar
greystreak92
Check the condition of the rubber seals extending down from the corners of the top. (Top corners of the tailgate will leak if these are damaged). When these vitrify they don't seal properly and begin to disintegrate.
Old Sep 20, 2009 | 07:39 AM
oatsj's Avatar
oatsj
Thanks,I will look closer.
Old Sep 27, 2009 | 11:33 PM
McLeod's Avatar
McLeod
This solved the rear window leak on my 95
Pappys53
23
Feb 18, 2017 02:00 AM
tiltbilt
38
Nov 23, 2015 10:03 AM
DGMFORD
1997 - 2003 F150
Apr 29, 2014 12:31 PM
baxterboy
6.7L Power Stroke Diesel
Mar 16, 2011 11:17 AM
Tptoe
May 26, 2004 05:23 PM
