Absolute Fan Clutch Test?
Old Jun 22, 2018 | 02:39 PM
JWA's Avatar
JWA
2003 E250 w/5.4 2-valve motor, factory air conditioning, 263K miles. After running at freeway speeds (65 MPH) getting a bit of coolant being pushed out of the degas bottle, normal driving without A/C coolant stays in the bottle. Will be installing a new Ford radiator cap, the degas bottle and t-stat will be replaced as the bottle has a small split that shoots a tiny stream out; coolant is fresh this past April. Photos:
Coolant temps as measured via a scanner through the DLC port shows 195F, stem thermometer placed in bottle shows just at 205 with A/C on, cap off and idling in the driveway. A/C leaving air temps at the vents is no higher than 45F when pressures have stabilized; heat through the vents is just about 100F.
Radiator might be partially clogged or water pump on its way out so if those need replaced that's fine---this is my money maker vehicle. Awaiting delivery of new Motorcraft YB3016 fan clutch assembly but before that's installed is there a sure-fire absolute proof-postive test I can perform to make sure it does need replaced?
This isn't about cost rather its about down time of the vehicle. please let me know if/what additional info is needed.
Also what wrench size is the fan clutch nut? I'm reading 30mm, 32mm or possibly 36mm---very confusing.
Thanks so much in advance!
Old Jun 24, 2018 | 07:07 PM
enriched&beyound's Avatar
enriched&beyound
Pretty sure it was a 36mm on mine ( its a 02' f150)
also it was right hand threads.....not like the older rangers and broncos that were LH threads
Old Jun 24, 2018 | 07:32 PM
JWA's Avatar
JWA
Thanks---that narrows the search down just a bit!
As I mention I've seen 30, 32 and 36 cited---one clever fellow on YouTube used a pipe wrench, properly adjusted though to not leave teeth marks. I myself prefer the correct sized wrench.
Old Jun 26, 2018 | 01:31 PM
Garden Spyder's Avatar
Garden Spyder
I used a monkey wrench, metric adjustable (Cresent), it worked great! I think its a 18 inch one.
Old Jun 26, 2018 | 02:05 PM
JWA's Avatar
JWA
That's probably the way I'll go too, use a pipe wrench properly adjusted to contact three sides of the nut. Once off I'll measure the nut and get the proper wrench, will report back what I find.
Thanks GS!
Old Jun 26, 2018 | 03:32 PM
Garden Spyder
Any time! Glad to help!
Old Jul 1, 2018 | 02:02 PM
JWA's Avatar
JWA
Okay so this is all done---replaced the fan clutch, t'stat, coolant reservoir bottle and radiator cap too---went a lot easier than I imagined. Used the pipe wrench carefully adjusted, with the help of the pulley holding tool (Gear Wrench 3900) a single not-too-hard whack and the old clutch nut spun free. Honestly the hardest part was removing the fan shroud in one piece---I wanted the extra room and visibility that provides.
The proper wrench size would be 36mm, here's photos of the fan clutch nut measured with a digital caliper:
I do notice the new fan clutch really improves air flow over the radiator, if the noise alone is any indication.
So thanks for looking in, glad to ask any questions.
Old Jul 3, 2018 | 06:06 AM
Im50fast's Avatar
Im50fast
Regarding airflow and noise:
ive noticed that my v10 e350 sounds most like a military hovercraft during the first .2 miles of cold driving each day. Granted it’s not idle but it is very low rpm- cruising 12-15mph out of my neighborhood.
And: air conditioner is weak at idle- with no airflow noise.
Those two symptoms seem like they’d indicate my fan clutch is doing the opposite of what it should. What’s your observations: before and after your new clutch?
Old Jul 3, 2018 | 03:52 PM
Garden Spyder
I believe they all sound like that when it is cold as I have had 5 of the 5.4L engines and they were all like that, which would be opposite intuition for me. I would have guessed the clutch would pretty much release until the engine warmed up, but evidently that is not the case.
None of the A/C units in the 5.4L vehicles have ever had super cold A/C. The one I have currently has the best so far.
Old Nov 30, 2018 | 11:22 AM
simplebuck's Avatar
simplebuck
This past summer I noticed that my E150's ac wasn't quite as cold as before.
Refrigerant charge was correct, though.
It had the original fan clutch, so I replaced it with the correct one from rockauto.
Before I installed it, I modified the temperature-sensing spring on the front of the clutch, to engage at a slightly lower air temperature than stock.
Did this by filing away some of the aluminum that holds the end of the spring in place.
Filed off about .050" , let the spring tip rest against the new surface, using some epoxy to hold the spring tip there.
This moves the spring position very slightly toward "engage".
And it does engage.
Just that tiny amount of change makes the clutch begin to engage sooner, and it gets to full engagement sooner.
It increased the engagement at idle, too ... a noticeable amount.
The downside is that during city driving in hot weather, with ac on, when the air temperature over the fan clutch is REALLY high ...
the fan roar is very noticeable, and at times the clutch stays engaged what seems like too long.
But so far it's been worth it.
The ac is a beast now .... and I feel pretty sure that underhood temperatures are a lot lower
Old Dec 1, 2018 | 04:34 AM
JWA's Avatar
JWA
My project has been finished for some time now---changed the radiator, installed new Motorcraft fan clutch, new t'stat so I'm fine.
If your A/C has the correct charge and its still not cooling very well could be the compressor is worn---you don't list your year, chassis or mileage so tough to say much more. Modifying the fan clutch doesn't seem like the best idea but that's just me.
In some cases I'm okay to modify something new but for the most part Ford engineers their parts to work together as is and off the shelf.
Old Dec 2, 2018 | 10:11 AM
simplebuck's Avatar
simplebuck
Glad your changes worked out ok.
My a/c is cooling pretty well now.
Will keep that in mind about the possibility of a worn compressor.
Thanks for the heads-up about no vehicle info.
I added a signature that I hope fixes that.
Old Dec 3, 2018 | 04:27 AM
JWA's Avatar
JWA
Put the vehicle info in whatever post you're seeking advice or help about---some users don't pay attention to signatures. What happens if your signature shows one vehicle and you're asking about something altogether different? IMHO those seeking advice should make it easy for those trying to help.
Its just good nettique ya know!
Old Dec 3, 2018 | 05:23 AM
Im50fast's Avatar
Im50fast
Signatures don’t show for people viewing on the mobile site.
Old Dec 3, 2018 | 07:18 PM
simplebuck's Avatar
simplebuck
ok, thx for the good help y'all
KC92F150
Nov 24, 2008 10:43 AM
biggreen79
24
Jul 27, 2007 08:17 AM
chaoscreature
Jul 4, 2006 12:06 PM
Kansas-Mike
Feb 23, 2005 01:41 PM
guzzler96
21
Apr 23, 2004 06:54 PM
